DisTrash
Hello,
Since yesterday i started to import filters from the FF filters library, but i have some questions :
1/ Actually i need to close FF and click on a filter to import it, then it opens FF and the new chosen filter, but after, then the software is open i cannot open others filters, i need to close it, import, close it Etc...
It is the good way to import or a simply method is possible.
2/ Can i and if yes where to find and save the filters i downloaded on the FF Filters library, to burn them on DVD, my favorites, a back up in fact.
And on an other hard drive, "in the case of " a problem comes.
Many Thanks .
Best Regards.
smile;) smile;) smile;)
It is not smile:)
I recommend you switch to the built-in Library browser for bulk downloading. Go to Main Menu > Tools > Options > Online tab and select the "Use the built-in library browser (obsolete)" option. After this, the link to the Library will be replaced by a button that opens the built-in browser. You'll be able to download multiple filters by first adding them to the download list and then downloading all at once.
They are located in %APPDATA%\Filter Forge\System\
(by default it is C:\Documents and Settings\YourUserName\Application Data\Filter Forge\System)
Totte
Übernerd
Filters: 107
There is a link on the webpage to set up your browser to find FF and "hand over" the download directly, (can't find it now, as it is shown whenever that fails).
The Library is on your disk (right click a filter to do "Locate On Disk", then you know where it is).
// Totte
DisTrash
Many thanks for your informations, i will test the next time i will download several filters, (i have downloaded lots today).
Have a nice day !! smile;) smile;) smile;)
DisTrash
Download filters by list works very fine, i downloaded lots of filters by just double clicking on them to add and just one more click and it's on my Hard Disk.
Awesome filters and awesome software, i will advice to my graphist friends.
thanks again.
+12 new in 30 days!
