KGtheway2B
KGtheway2B
Old Steel Cable by Kisakumedia
http://www.filterforge.com/filters/8499.html
KGtheway2B
KGtheway2B
I can't believe nobody has commented on this yet!
Amazing job!!
Your climbing rope texture is totally excellent as well. I'm excited to see your future stuff, hope you stick around and keep it up!
ronjonnie
Designer / Artist
Filters: 320
Hey Kisakumedia,
YES! I Like It! VERY NICE!
What is next?
Have a GREAT day! smile:)
Ron
uhm, can it do a single strand?
KGtheway2B
KGtheway2B
It is a single strand. It's designed to wrap around a cylinder.
Having a flat strand sitting with stripes of alpha beside them would be useless imo.
tigerAspect
Filters: 9
Cool! I like the Diffuse map by itself more than the final texture smile;) It'd make for an awesome corrugate metal texture as well smile:D
say what now? how is that a single strand? grant you, i'm not a big 3d guy, so i'm not saying you're wrong, but i dont quite grok. care to explain or show an example of how that becomes a single cable, KG?
KGtheway2B
KGtheway2B
Larger cables are made of a bunch of little cables twined together, then those are twisted together again. The big cable in this pic shows it.
Since the texture tiles both H and V you would simply wrap it around a cylinder (like I did with a column texture in this thread: http://www.filterforge.com/forum/read...ssage59607 ) then continue it vertically. Voila!
i know what cables are and how they're made. but to wrap that around a cylinder like you're talking with the column, the column was just one instance, not several like this cable is. but, quite true that i'm not a 3d man. i could see it if it's taking only a portion of the image and offsetting and then applying the other portion of the image...i think, but even at that, i still dont quite see it. anyone got an instance of applying this filter to a 3d wrap?
Kisakumedia
Game Artist
Filters: 2
Thank you for all your comments!
I'm glad you like my filter and I hope it's of any use to you smile:)
I see that there is some hot discussion going on there so I try to explain everything to you as good as I can.
First of all, thank you KGtheway2B for your hard work trying to explain whats going on in 3D.
Thank you Kraellin for your questions, I'm pretty sure, that there are more people who want to know how this will work in 3D.
I made some quick screenshots to demonstrate how I use these textures in practice (these are the new textures, coming with the update, as soon as it makes it to the server smile:| ):
I'm starting with the first preset that is rotated 45 degrees:
Just a quick hint here: Its not so important if the texture is rotated in the first place or not. With the second texture, I will show you how to get the same results with non rotated images.
Applied on a simple cylinder (with some bending):
with visible edges
without visible edges
This is how it will look like on the 3D model, but in order to achieve this result, the UV-Layout (2D projection of all the 3D faces) has to be created.
First of all, the screenshot of the UV-Layout:
It shows all the faces of the cylinder.
Link to full size
Here you can see how the texture (that is tiled some times) is projected on to the 3D geometry, controlled by the UV-Layout.
But how does it work with this texture?
It's very simple in this example. Just rotate the UV-Layout instead of the texture:
Link to full size
I hope you could follow along with my little tutorial smile8)
If you want some more detailled information, i could make a video tutorial or something like that but only if can spare some free-time.
Have fun with my texture and try the updated version as soon as it is uploaded!
thank you, kisa.
i guess what i dont get on all that is, why go through all those hoops? i mean, what's the advantage to doing things that way. it just seems pretty convoluted to me when you could make one 2d cable and simply wrap it around your 3d object. mind you, i'm completely lost on what this UV thing is. UV to me always meant ultraviolet and i can see that's now how you all are using it smile:) so, seriously, why this method?
KGtheway2B
KGtheway2B
I don't understand how this is still confusing you...
Can you show an example of your supposed "non convoluted" method?
(Note: I can't tell if you're kidding or not.)
UV is how 3d programs apply 2d information (such as an image) to 3d information like a 3d model. Geometry w/ a UV map has X,Y,Z as well as U,V coordinates. Those U and V coordinates establish a 2d area, which is your texture. UV maps can look very different from the model.
You would still have to provide a UV map to apply the texture to any bending geometry. This method just allows the pattern to be repeated. This is extremely common, particularly when you need to save texture space.
Kisakumedia
Game Artist
Filters: 2
I guess what you mean is to make a photo from a real cable and wrap it around the 3D model, right? Or did you mean to make a texture of a single cable?
Getting good images from real steel cables is very hard and even harder to make it fit to the desired 3D model. It's not impossible though. There are people who do it that way, but I think you have more control with self-created textures.
If you meant to make a 2D cable texture and wrap it around, then I can tell you that this is exactly what I was doing here smile:)
It may not look like it but this filter creates a piece of a cable, or several cables (you can set the repeat count to 1 to get only 1 cable piece).
The reason why only a piece of the whole cable is used, is to safe texture space/resolution. In 3D, it's always better to repeat small textures than having one big texture.
But that's an art of itself smile;)
thank you, corvus. no, i wasnt joking. i've only worked in 3d just a tiny bit with game editors. so, they're mostly still a mystery to me. i had never heard of a uv layer.
ok, you're applying this a whole lot differently than i thought. and no, not talking about a photo here. what i would have thought, if i were trying to make a cable texture, would be you'd make a single image of a single cable, no extra faces or anything and simply apply it repeatedly end of cable end to end of cable end, that the single cable would wrap completely around your 3d model and you'd just repeat this for however long the cable was.
as i look at your examples above, kisa, you're wrapping it almost horizontally, so that the individual strands of the cable are almost perpindicular to the vertical axis (the elongated axis in this case). i hadnt thought about that.
ok, i think i get this now. i've not worked with 3d models for a while. i forgot you have all these faces rather than a single wrap. so, you dont want to have to slide each texture face down to make it work. ok, i see.
thanks, kisa smile:)
and might i add, pretty brilliant and a good texture. thank you for the help smile:)
