Miavir
360° Image Rotation Using Bomber by meyendlesss
http://www.filterforge.com/filters/8398.html ![]() In ancient Egypt, Cats used to be revered as Gods.
Cats have never forgotten this. And rightly so. |
| Posted: April 13, 2010 12:34 pm | ||||
Miavir
Note, even under Beta 2.005, this technique remains valid. I used this to make my own 'Amulet' filter execute about 30% faster (will be released soon after I add on some stuff ). By comparison, doing this using the 'Rotate' component introduced in 2.005 was actually a shade slower than the bomber version, had some issues due to parts of the image being duplicated at the corners that the bomber didn't, and at the same time turned the filter into a non-seamless
So I'll stick with the bombers.In ancient Egypt, Cats used to be revered as Gods.
| Posted: April 13, 2010 12:45 pm | ||||
meyendlesss
I considered asking to have this filter/snippet removed when stage 3 was released, but also noticed that it's sometimes faster than the rotate component.
Thanks for pointing that out, Miavir. |
| Posted: April 13, 2010 2:40 pm | ||||
| 3dsBlend |
When you rotate the image, the picture remains seamless.
Haloo! Enjoy this page while you're here! xD |
| Posted: December 25, 2010 12:02 pm | ||||
I have just found this very simple snippet and think that it may be useful for what 3dsBlend has told, as many filters may not be able to use seamless tiling because they have the Rotate component that is not compatible so using this may make it seamless although you can not use any other non-seamless components Examples of non-seamless components include Scale, Rotate, Free Gradient, Free Ellipse, Free Polygon and Free Rectangle. Even 10 years, is still useful in FF9 And Rotate is not the only thing that breaks the seamless tiling, also Scale component does it, BUT you could also use this same thing to probably use the size in some limited way AND this idea can ALSO be used additionally for the following things using also bomber if wanted to use just ONE only element 1 - Offset X and Y with Bomber 2 - Scale Size with bomber to avoid repeating of the source image 3 - Tint Color and Tint amount of just one only element using bomber 4 - Squash with bomber Each of these can be used alone and just one of them when needed Here is the modified filter Bomber using just ONE element.ffxml |
| Posted: November 1, 2020 1:55 pm | ||||
+12 new in 30 days!
11 unregistered users.
