Sign Guy
Posts: 554 |
Just read a request for a seamless tile that would emulate the look of the stainless steel backgrounds used widely for old diners and hot dog carts. Probably would be a fast HU for somebody.
Fred Weiss
Allied Computer Graphics, Inc. |
| Posted: June 17, 2009 12:06 am | ||
Redcap
Give use an example and I will make you one
| Posted: June 17, 2009 7:57 am | ||
Groovy might be worth a look.
| Posted: June 17, 2009 9:43 am | ||
Sign Guy
Posts: 554 |
| Posted: June 17, 2009 10:47 am | ||
| tigerAspect |
My stab at this is up: http://www.filterforge.com/filters/7412.html
I misremembered your request and did it as brushed metal, but that's removable. |
| Posted: June 19, 2009 10:46 am | ||
Sign Guy
Posts: 554 |
Thanks for trying.
Fred Weiss
| Posted: June 19, 2009 12:24 pm | ||
that's actually pretty good, tiger, but that kind of stamped metal is not that well defined, at least as i remember it. your squares are too perfect. it's more of hills and valleys thing without the sharp definition. i'd have to check the scale again, but i think yours might be a bit large that way. try a google image search. i'm sure it's available. i just dont know the proper name for it... cart metal? stamped metal? plate metal? stainless plate? hot dog metal?
| Posted: June 19, 2009 1:15 pm | ||
here, try this link: http://64.235.35.226/hotdogs/cart.jpg
| Posted: June 19, 2009 1:18 pm | ||
and here's another: http://images.google.com/imgres?imgur...s%26um%3D1
click on either image for a popup picture of the carts in a larger size. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 19, 2009 1:20 pm | ||
| tigerAspect |
Ah, finally some good reference. Thanks.
As far as i can tell, the squares themselves are well-defined, but the heightmap is rounded, not square. Is that more what you're after? |
| Posted: June 19, 2009 1:52 pm | ||
yes, the squares are fairly well defined, but not like you had it. that was too sharp on the squares. you're in the ballpark; just look at those pictures i linked to. they're pretty good examples of 'hot dog cart metal'... that's what i used as a search in google images.
| Posted: June 19, 2009 2:02 pm | ||
| Posted: June 19, 2009 2:07 pm | ||
and on a diagonal, of course.
also, be careful when looking at those hotdog carts. some are done in diamond plate and some in cut metal rather than stamped. the biggest difference in cut and stamped is that the cut will be smooth where the stamped will have a pattern. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 19, 2009 2:08 pm | ||
| tigerAspect | ||
| Posted: June 19, 2009 2:39 pm | ||
ok, now you're really close! those squares look much better... not so sharp. i'd say drop the height on the light parts just a bit and you've mostly got it. add roughness to suit, if warranted. if that's a surface type, then just changing the lighting might be enough of a height drop to get it.
| Posted: June 19, 2009 3:37 pm | ||
| tigerAspect | ||
| Posted: June 19, 2009 4:29 pm | ||
Sign Guy
Posts: 554 |
| Posted: June 19, 2009 4:35 pm | ||
yup, that's very close. look at fred's last picture at the middle left of the image, the side panel of the upper part of the cart. that's what i'd shoot for. yours still looks a bit too high in the height. that metal is actually pretty flat on the cart. i know it's tricky to get the reflection without adding the apparency of more height but you really are close.
| Posted: June 19, 2009 8:04 pm | ||
I say also less reflection blur, 25-33? It's turning out good so far
| Posted: June 19, 2009 11:19 pm | ||
| tigerAspect | ||
| Posted: June 20, 2009 6:44 pm | ||
Sign Guy
Posts: 554 |
I think what you need is for there to be a tile type bevel coming out of the seams that then transitions into a flat surface. Then finish it off with a shiny slightly brushed metal look.
Fred Weiss
| Posted: June 20, 2009 10:18 pm | ||
you're so close i can practically feel it. since you said it's a surface type filter, try cutting the whites on the height map down. maybe with a threshold or levels component. that shld knock the whites down and flatten things a bit. also, check your hdri lighting. the hdri can sometimes impose a false height to things. try different ones.
if you look at fred's last posted image again, on the left side, middle, down on the middle of the cart, the little part that sticks out and has trays in it, that panel on there shows the metal without reflections. you might try for that, instead of the higher reflected parts. that might make it easier to drop the height apparency. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 21, 2009 9:25 am | ||
| tigerAspect | ||
| Posted: June 21, 2009 12:01 pm | ||
| tigerAspect |
Updated with the latest version. I added better crumpling and dents.
http://www.filterforge.com/filters/7412.html |
| Posted: July 6, 2009 11:14 am | ||
sweet!
| Posted: July 6, 2009 12:51 pm | ||
15 unregistered users.
