ORVATSEL
Filters: 2
Hio
How cn I edit a variant-preset and not the default preset ?
When I like one of the presets and try to edit it - it opens the filter in its default preset and not the variant.
NIR
Hello ORVATSEL welcome to FF..
On the upper right-hand side of where the presets are there is a little arrow...If you click on that there will be a sub-menu that pops up...First select the preset that you want to edit...Then click on that arrow for the menu then choose "add preset"
This will give you a copy of that preset but you can now edit that....
So now choose the preset this process created and start editing..Moving the sliders and all that.....Once you are done and got it the way you like you can go back to that sub-menu and choose "Update Preset" and it will update that preset with the new settings.....Make sure that you have your newly created preset selected otherwise it won't update....
However if you are talking about editing in the EDITOR itself...In the filter editor and looking at the construction of it check the "Result" component....Selecting the
little window thing at the bottom marked "Filter Controls" this will bring up the filters controls, presets and everything that you would see outside the editor..So you can choose the preset from there also.....I don't think you can do this in the basic versions thou...Since you can edit the filters... smile:|
ORVATSEL
Filters: 2
CFandM thx
but I want to edit it in the Filter Editor and not in the sliders area.
EDIT: you just posted anoter reply - will check to see it
NIR
ORVATSEL
Filters: 2
Ahh Huh !
Thanks - this is exactly what I was looking for - thanks and merry chrismas !!
NIR
CFandM wrote:
.I don't think you can do this in the basic versions thou...Since you can edit the filters... Confused
hehe yep I was posting when you were Merry Christmas.. smile;) smile:) smile:)
I meant to say in the basic version you can't edit the filters... smile;) smile:)
ORVATSEL
Filters: 2
I have the pro version.
thanks again.
Nir (basically a Hanukkah celebrator...)
Then Happy Hanukkah smile:)
Equator
Useful topic
