ssamm
Filters: 21
I'd like it that when filters get removed from the FF library and placed into the "My Filters" folder, that those filters get specifically named.
I'm guessing that a least two of my filters were removed from the library(?), because when I went to try to use them through my slimmed down "Favorites" folder they were no longer there. And when I tried to re-download them from the online library (using the nice, online search capabilities), they wouldn't download.
This caused a bit of confusion -- where I had to finally conclude that my desired filters were no longer available through my "Favorites" folder or through the FF library --- and so I'd have to search my mega-overloaded folder named "My filters" for them.
For background information purposes:
The first filter (which I'm guessing was removed) had a "High Usage" rating.
And the second (removed?) filter used an outliner effect that used the Refraction component (where no other "outliner" FF filter used that effect) and I preferred it, with it's colorizations and blending modes over similar previous filters -- i.e. it had something unique about it's effect that I preferred... (I'm just stating my case of why I submitted it.)
(I'm also thinking...) if my filters were removed because they were too similar to other filters, then that's cool -- they were only variations on a theme... smile:)
Still, with my work schedule, I only have a very limited time to experiment with Photoshop and FF; so when I find that I can't find what I want when I want it -- it's kind of annoying. So, my essential point here is: I think it would be nice to know when a "Favorites" filter gets removed (rather than me having to go through some rigmarole of trying to figure out what happenned).
(And, yeah, of course, it's disheartening to see my own filters getting removed from the library (if that's what happened) -- but I realize, FF has a huge library, and I'm sure it's got to try to slim itself down somehow. smile:) )
SSammm it unlikely the filters were removed especialy a HU with out telling you or you requesting [ obviously you didn't do that ] it more likly an error has happened in the library - I'd send them an email smile:)
ssamm
Filters: 21
Carl,
Thanks for your voice of reason/sanity.
I think what happened was that there was some sort of error on my side with my computer. After my previous post, I started noticing I couldn't download any new filters (and meanwhile my filter library seemed to be partially wiped out).
I'm not sure what happened, but after re-booting my computer, Windows did a Scan Disk Check (or something?) and things seem to be working again -- where at least I can download new filters and I see that my filters weren't removed...
(Heh, heh, I'm an idiot! smile:) )
ssamm, this also started happening to me after the last program update. I just do a <Tools/Filter Updates>, and even if there are are no filters to update, it still repopulates (actually re-registers) everything back to the way you had it.....
I usually get a "categories restructed" message or something like that when some filters get removed and thrown in my 'my filters' area. So if you don't see that message first, something is maybe wonky and ya should restart and try again. But yeah, other than that, I've not had any filters thrown out of the library without asking that they be removed, that's just my experience with all that. smile:D
Just so long as you don't actually loose anything, eh??? smile;) smile:D
I'm glad you worked it out SSamm smile;) smile:)
13 unregistered users.
