ssamm
Filters: 21
This may have been requested before, but...
I'd like the message: "This filter requires a selection" to be moved, e.g., above or below the initial image (rather than on top of and in the center of the image).
I think the Selection component can be very powerful, but (in my personal filters) I usually only have the Selection component used as an option where it can be turned on/off by a switch controller -- so a selection often, isn't "required", but just an option... (And for those times I don't use a selection, the message is fairly annoying.)
P.S. If the message has to be on the initial image, my wish would be to have it on the very bottom part of it (since heads/faces are generally on the upper part).
Filters: 703
Could this message be moved fr om the center of the screen?
If we have a selection component in the filter, this message always appears, not allowing us to completely see the result.
Also, there are filters where the selection is only an option ( when the selection component is connected with a switch ), so the message "This filter requires a selection" is false.
it seems that there may be something wrong in the way FF uses the selections load, because is right that you can put the selection input only as an option, and even you can put a checkbox to disable it so is clearly optional, but seems that it does not care, it will always require a selection, or at least, always will be shown the message
And I think that it is in middle and center of screen so you surely see it and know that you have to load a selection
One way if the selection is optional and not an essential and required part of the filter, is to enter inside the filter and switch it off, I mean disconnect the selection or delete it, so this surely removes the warning message smile:)
