Quasimondo
Quasimondo
Filters: 32
I think it might be a nice idea to start some challenges with the goal to find out how to construct certain effects - ideally those that on first look seem to be impossible to build with the current toolset. Feel free to add new topics with other challenges - but please don't add a different challenge to this thread.
So my first challenge to you is to construct a circular gradient - not a radial one which we already have. Ideally it is black at 0 degrees, is 50% grey at 90 and 270 and white at 180 - but of course the perfect circular gradient that I am looking for can display any kind of color combination.
Something like this?
I'll see what I can do.
Quasimondo
Quasimondo
Filters: 32
Yes. Good job! Are you using refraction?
Using Photoshop actually...
I just wanted to make sure I knew what you wanted before trying to make it in FF.
Quasimondo
Quasimondo
Filters: 32
Ah okay - but it's actually a good idea to use a photoshop prepared gradient as a reference - if you load this as an image and layer the calculated gradient with difference blend mode onto it you can see how good the implementation is.
Here's what I've got so far. Not great but maybe something you can work from...
http://uberzev.googlepages.com/RadialGradient.ffxml
Quasimondo
Quasimondo
Filters: 32
Oh - that's not so bad for a start. Good work!
Nice so far. I was thinking of how to create this myself. I had a easy start then it turned out it was not going to work the way I wanted. I will give this a go. I will post results if I have any.
I think I nailed it...
http://uberzev.googlepages.com/CircularGradient.ffxml
Thanks to byRo for his brilliant 'TRUE Circles' from which this is based on. smile8)
For comparison here's Photoshop's version using the angle gradient...
Here's a better version that use my tiles-to-circles method...
http://uberzev.googlepages.com/CircularGradient3.ffxml
photoshop mockup...
Don't mind me, I'm just having a bit too much fun... smile:D
Here it is, the holy grail...
http://uberzev.googlepages.com/CircularGradient4.ffxml
Simply apply any elevation gradient you like and presto...
Quasimondo
Quasimondo
Filters: 32
Whoohoo - that is brilliant!
Can I say DARN you beat me to it. I will also add HURRAY and a big congrats on working this out. Very clever indeed.
Uberzev, this is brilliant. Looks like it's a proper circular gradient!
nicely done!
ok, for us non-technical types, what is the difference between a ciruclar gradient and a radial gradient and the also mentioned, angle gradient?
craig
Lucato
FF addicted
Congratulations GeniUberzev! You're a genius! smile:) Now make It rotate from 0 to 360º stepping one. smile:) Just kidding. Congrats!
byRo
an Englishman in Brazil
Great work, uberzev!!!! smile:)
I was a bit stuck on this one, and ended up "borrowing" a few of your ideas - but I believe that mine is still quite different enough to be interesting.
Is there a second prize?
Rô
Circular Gradient byRo.ffxml
byRo
Rô
Quasimondo
Quasimondo
Filters: 32
Lucato wrote:
Congratulations GeniUberzev! You're a genius! Smile Now make It rotate from 0 to 360º stepping one. Smile Just kidding. Congrats!
That's no big deal with his method - just exchange the spectrum with a black to white gradient and then change its offset to rotate it.
Ken
CameraKen
Filters: 16
Well Done Uberzev and Ro.
How about a spiral as the next challenge?
Ken.
It pains me to admit it but my method is just not 100% accurate. Note the difference between the 'ideal' version and my attempt...
Here's 'ideal' on its own...
Anyway here's another variation of the effect that uses byRo's circle technique. I can't seem to get it to work just right, but its simpler than my tiles-to-circles method. Maybe someone here can figure it out...
http://uberzev.googlepages.com/CircularGradient5.ffxml
That's easy....
http://uberzev.googlepages.com/SpiralGradient.ffxml
My method isn't very efficient though.
Some interesting distortions are possible as well...
http://uberzev.googlepages.com/CircleDistortion.ffxml
As a perfectionist I hope to see the underlying accuracy issues be resolved before people start using these techniques in their 'official' filters. smile:D
Sorry, nobody remembers who came in second.
Anyway, I initially gave the square method a try but found it didn't have any advantages over the circular variation. smile;)
From my understanding there are two types of circular gradients, according to Photoshop their names are RADIAL and ANGLE.
RADIAL...
ANGLE...
I suggest we use these more descriptive names instead of the ambiguity of 'circular'.
Ken
CameraKen
Filters: 16
Uberzev.
Another great Job and a nice Flower. smile:)
But I was thinking more of a Spiral
Ken.
thank you, uberzev.
craig
Quasimondo
Quasimondo
Filters: 32
Yeah great! That was my original intent of this challenge - to use the gradient as a base for circular distortions.
smile8)
byRo
Like
Polar Coordinates smile:D
Rô
The 'official' version is now complete...
http://www.filterforge.com/filters/671.html
Take a peak 'under the hood' if you like, it's much less complicated than my previous versions.
Version 1.5 is done...
http://uberzev.googlepages.com/Circul...t1.5.ffxml
Quality has been greatly improved.
Photoshop Ideal...
CAG 1.5...
Difference...
Quasimondo
Quasimondo
Filters: 32
Excellent job! Thank you! Yes the improvement is clearly visible. I've already updated my filters that make use of the gradient with your new version.
http://uberzev.googlepages.com/Circul...t1.6.ffxml
Minor update, nothing too exciting. Just simplified things a bit and made sure the 30° angles were accurate.
33,814 Registered Users
+13 new in 30 days!
+27 new in 30 days!
