I have downloaded the new Photoshop CC ( I have a subscription to the adobe cloud and as shown in this thread and have tried both Filter Forge 3.0 and 4.0 and both works very well without any problem, at least with the few images I have tried it
You do not need to reinstall filter forge, just go to the old plugins folder of the previous version and copy the "Filters" folder into the new Photoshop CC Plugins folder
I have tried even more with selections, layers, and transparent background and any way I use it, FF3 and FF4 works right always
I have to say that I forgot to say that what I am saying is ONLY from the Windows 7 64 bit side, as I do not have a Mac to test it, so it could be good if someone with a Mac or someone from the FF team could confirm if it works right and well also in the Mac side
Nobody else that has a mac and is subscribed to the Adobe Cloud OR is subscribed to the Photoshop subscription alone can test the new FF in Photoshop CC?
I think and suppose that if it works well in windows, it will probably will work well also in Mac, but can´t know it
Filstar
Hi, I have installed Filterforge Photoshop Plugin 3.014 Pro (Registered) and i'ts crashing Adobe CC. smile:?:
Filterforge has been installed on my D: drive:
D:\GFX2D\Filterforge\Plugin\x64
I have copied the photoshop plugin D:\GFX2D\Filterforge\Plugin\x64
C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\Filterforge
When starting Photoshop CC and select Filter, I get this error:
Operating system: x64 Edition (6.1 build 7601) Service Pack 1
Physical memory: 16381 MB
Number of processors: 8, available: 8
Processor info: Intel® Xeon® CPU E5440 @ 2.83GHz, ~2812 MHz
Filter Forge x86-SSE2 3.014.28114.8386 Release-SSE2, April 19, 2013 11:04 [23/06/2013 18:18 AUS Eastern Standard Time]
CacheStorage limit reset to 1612.743750 MB.
Blowing up balloon. Current size - 128.00 MB.
Exception caught at thread 000012B8 'Application':
<class XFW::ArgumentError> The handle 001BAB90 is not a valid window handle.
<unknown file>(0) : <unknown function>()+0 at 005A83A0 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00CF56F8 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00BC5120 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:7599C41F, SS:ESP 002B:0018BF30, EBP 0018BF80, FLAGS 00200216
CONTEXT_INTEGER: EAX 0018BF30, EBX 00000000, ECX 00000003, EDX 00000000, ESI 00B201A4, EDI 0018BFC0
Thanks for your help in advanced!
I suposse that you are using Windows 64 bits and not Mac.
I have copied the photoshop plugin D:\GFX2D\Filterforge\Plugin\x64 to
Well I think that maybe the problem may be that I think that you have to specify WICH version of filter forge plugin you have copied
Here is how I have copied it myself and works right
C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\Filters\Filter Forge 3
C:\Program Files\Adobe\Adobe Photoshop CC (64 Bit)\Plug-ins\Filters\Filter Forge 4
And inside of these you have to copy in each one also the XML configuration file.
Filstar
Thanks SpaceRay, I did exactly what you described (including tons of variations) - and still no luck. I only have Filter Forge 3 (preordered v4 but haven't installed the beta).
I always keep getting the same error: <class XFW::ArgumentError> The handle 0020B1C0 is not a valid window handle.
And yes, the config file (Filter Forge.config) has been copied into the same folder as the .8bf file.
Any other ideas or suggestions, please let me know.
Well, you can try to reinstall Filter Forge, and so it will detect and see that you have installed the new Photoshop CC and it will install the new plugin inside of it, but for this you must delete the plugin that you have copied inside Photoshop CC
Reinstalling Filter Forge will NOT delete anything and will keep everything as you had before, so there is no danger in this.
Our installer doesn't detect PS CC yet.
@Filstar: have you tried running the 32-bit version of CC with Filter Forge?
Filstar, Are you using windows or Mac?
OH, Sorry that I thought that FF could detect ANY newer version without having to modify the software, I thought that was something that it was something automatic that any photoshop version could be detected.
Then we will have to wait for the new updated version of FF, although meanwhile for me it works very well just putting the FF 64x plugin inside plugins Photoshop CC folder, In windows for me it works, I am sorry that I can´t help anymore as I do not know what may be happening to you
Filstar
Thank you GMM abd SpaceRay for your reply! I sent an email to support 36 hours ago but they haven't replied yet :/
[SpaceRay] Well, you can try to reinstall Filter Forge...
I did, no change. By the way, I downloaded the trial version from the main website, there is no other download link that I should know of, correct? And yes, it only detects CS5, not CC but even then, it didn't copy any files into the plugin folder(?).
[GMM] have you tried running the 32-bit version of CC with Filter Forge?
I don't have Photoshop CC 32-bit installed, only 64-bit. But I tried it on my CS5 (luckily I haven't uninstalled yet):
Photoshop CS5 - 32bit - Filter Forge plugin WORKS
Photoshop CS5 - 64bit - Filter Forge plugin CRASH (of course x64 plugin copied into plugins folder together with .config file). The error message: "<class XFW::ArgumentError> The handle 0012B1B0 is not a valid window handle." appears.
[SpaceRay]...for me it works very well just putting the FF 64x plugin inside plugins Photoshop CC folder...
Lucky you. Hm, I wonder if it has to do with MS Visual Studio Runtime Libraries or .net Framework conflicts, missing or not being installed? Who knows. Thanks SpaceRay for your help, much appreciated! smile;)
Filstar
Hey, just checked my emails and support replied back. Great news!
In "Filter Forge.config" set <IndependentUI value="true"/> and it works in Photoshop CC 64-bit! Just thought I let you know. Cheers
Good news that you have been able to solve it thanks to the customer support
All was about changing that only setting? smile:?: Something simple that breaks it
As said, good that this works
ultravilot
ultravilot
Mac user here, but I won't be of help because I use FF in standalone mode. As for Photoshop, I'm sticking with CS6 until it no longer works. I'm not going to risk my files to the vagaries of a rental system and the cloud. I'm also switching over to PhotoLine as a replacement for Photoshop.
Russ
I am running PS CC on Mac OS X, and I have not been able to get the FF installer to make FF work as a plug-in. It runs fine in stand alone mode.
Edited to add: I tried deleting the Filters folder from my PS CC install, and copying the Filters folder from my old PS CS6 installation over to the PS CC install, and it worked!
So it appears to just be an installer issue.
~ Russ
+12 new in 30 days!
