Arial TD Numbers Snippet by ThreeDee
http://filterforge.com/filters/11542.html
Great and very good that you have also made the numbers available and not only the Arial alphabet letters and this is available already in the online library AND now it has the transparent background that is much better than having it with a white background.
It is very well organized and well done, thanks very much for all the hard work and all the time you have spent for making by hand each one of the individual numbers and arrange all of them in clean organized groups
Hafgandil
Hafgandil
Filters: 4
I definitely need to check this out!
Now nearly 3 years after, I love each time more this Filter and the awesome and amazing work than here for making this letters and the way they are done and how the can be changed and customized
And the reason to put this post is that now is possible finally to use all the letters AND all the numbers, and use them ALL AT ONCE, and do not have to be choosing only 5 or 10 of them (5 limit of old bomber) and make complex bomber arrangements, now with FF 5 bomber plus is very easy to use them all together in the
Again I can not thanks you enough ThreeDee for making this and be able to have fonts and numbers inside FF, something that FF team did not include in FF 5
