Arial TD Font Snippet by ThreeDee
http://filterforge.com/filters/11541.html
Great and very good that this is available already in the online library AND now it has the transparent background that is much better than having it with a white background.
It is very well organized and well done, thanks very much for all the hard work and all the time you have spent for making by hand each one of the individual letters and arrange all of them in clean organized groups
Lucato
FF addicted
I had to log-in just to say congratulations to you, because what a hard work you have passed through! Amazing job!
Thanks for sharing such snippet.
It will be great if one day we get to select a filter/snippet and into FF select "Make a Component". :0)
Have a great day and congratulations once again.
Lucato.
Log off. ;0)
Excellent snippet to make many filter typographic variations
To start, now thanks to this new creation, I have been able to modify my previous Alphabet Texture Maker filter that was not so good before, but now with this Arial FF font it looks much better smile:)
Here is the built-in FF Lionfish with letters
Here using bigger letters
And here using the LadyBug FF built-in
All these examples are only using 5 letters, I want to be able to use all the letters, and not only 5, so I will modify the filter for this.
Here is a another example with my own images
Love how it looks
Here is the same as above but showing the real final big size
ALPHABET FLOW
And what would happen if you taken the awesome and well done Jelly Bean Art by Mongoose King and replace the Jelly Beans with these Arial letters? smile:)
And another example of this Alphabet Flow
And here is the same as above with bigger detail to see how the letters flow
THIRD EXAMPLE
ALPHABET FLOW 2
Another different way of making letters flow is using the awesome and excellent Paint Chips by b15fliptop
Here I have just used one letter to try it and see how it looks as this is a bit more complex to add multiple letters although can be done
and using the FF built in Kingfisher
FOURTH EXAMPLE
ALPHABET CREME
Now for something completely different, and good for morning breakfast smile:D
angelize
angelize
Filters: 17
I like those! I'll bet that last one could be modified to make alphabet soup!smile:)
Great work 3D ! Is it possible to get the entire alphabet ? smile:)
Is it possible to get the entire alphabet?
All the letters are there, both upper case and lower case.
YES!, As ThreeDee have said the whole and complete alphabet is already available in the filter, is just that there are only 20 preset limit so they are not shown all of them.
Yeah, you're right smile:)
Nearly 3 years after, I love each time more this Filter and the awesome and amazing work than here for making this letters and the way they are done and how the can be changed and customized
And the reason to put this post is that now is possible finally to use them ALL AT ONCE, and do not have to be choosing only 5 or 10 of them and make complex bomber arrangements, now with bomber plus is very easy to use them all together.
Again I can not thanks you enough ThreeDee for making this and be able to have fonts inside FF, something that FF team did not include in FF 5
Although I love this font and is very well done, I wonder if there could be an easy way to make it customizable the height and width as is possible in the TD Europa Sans Caps Proc Font Advanced
I am already trying myself to be able to modify the letters, but as they are built differently using curves, it seems that you should modify them one by one, so instead of this I am thinking about a possible to way to enlarge the result instead of each letter
I have tried to use edge detect to increase the edges of the result, but it does not works as expected, will see to make it in another way, as using blur would slow it very much
Filters: 191
SpaceRay, I think that you can put a Scale component right before the output and use the following settings:
Center X/Y: 0.5, 0.5
Scale: 1
Squash: 0 is the original, try out - and + values with a control to change the width or height.
UPDATE: In a little while I will give you a snippet with constant height letters and customizable width.
Thanks Rick, I have already tried this already and it does not work, because the scale does not change the width of the letter
I agree that the squash idea may work, but as said the width of the letter is not modified
I have also found this outline increase made by ThreeDee in this thread and it seems to work increasing the size of the width of all the letter, it works right with but the problem is that it has a limit where it will make the hard edges rounded on some letters like S or G
Maybe there can be another component that can help to increase the edge or control more the result of maximum
I have simplified it to use only the Maximum component, as the other additional options makes the letter more even more round
Here below is attached the filter that I have made (well, really I just attached a maximum component at the end)
this ones above are the result of rounded edges
Filters: 191
Here is the modified snippet.
Arial TD Font Snippet width.ffxml
Filters: 191
and a test letter...
Thanks very much for the idea and using it this way, it works well for changing the size sideways width, and I have added in the end a maximum component, and now I am able to squash or expand the letters sideways and also increase the width with the maximum component from ThreeDee
Will put the filter here when I finish it
Filters: 191
In using this snippet, I found a minor rounding error in the lower case h. I've highlighted the component I modified (Profile Gradient) by changing the Offset from 0 to 0.001. The screenshot here from the letter h shows a thin black horizontal line which is not easily seen unless there is a light background. I'll post a fix in the next post.
Filters: 191
I ended up not making a fix, I found the thin horizontal line issue with the following characters: h r m n s 0 (zero). The main reason I found these is the use of faux bold, which made these easier to see. If you want to see how I fixed these, look at the Profile Gradients in the individual groups that house these characters in Globes 9x9. The fix usually meant changing the Black values to something a little bit higher than 0. I'm putting in an update for Globes in the next couple of days to add more characters and to fix the 0 character. The rest have already been fixed
27 unregistered users.
