| Posted: June 11, 2013 5:58 am | ||
Nice and well done 3rd version, this is even better than the last one and like it more and from the presets I see it makes lovely patterns.
Thanks for upgrading it and making it better and have made a new separate version instead of replacing the other one. |
| Posted: June 11, 2013 6:00 am | ||
Biomechanic
Posts: 122 |
This does not work in the Beta version...
All I get are diagonal lines J |
| Posted: July 22, 2013 4:50 am | ||
Biomechanic
Posts: 122 |
**update**
I installed the latest Beta and it now on opening the filter displays correctly... But, if I create a new blank image, it reverts back to diagonal lines WTF!? J |
| Posted: July 22, 2013 5:07 am | ||
The filter uses an image to produce results. You'll need to load an image in to see stuff. The filter can be easily modified to generate content without source imagery. You can feed it a perlin noise component (or any noise for that matter) in replacement for the image component.
I have no idea why the beta failed on your first run. That's something FF might need to solve. [Note] Categorically this filter should be listed as an "effect" filter. Effect filters generally use images as an input. While there are some exceptions most filters in this category will use images. |
| Posted: July 22, 2013 7:12 am | ||
Biomechanic
Posts: 122 |
Thanks Skybase and sorry, I already figured that out when I realised which category the filter was in....
'mimics putting a gun to his head and pulling the trigger' J |
| Posted: July 22, 2013 9:27 am | ||
Biomechanic, here's a simple example mod of what I'm talking about!
Optical Chaos 3 - No Image.ffxml |
| Posted: July 22, 2013 10:12 am | ||
OH!! WOW!! I have just discovered that the shapes in this filter are created by THE SOURCE image you have loaded, and I have been using the settings and presets without knowing that
If I liked this filter before, now I like it much more and then is more creative and better Here is what I got from this tiger head |
| Posted: September 22, 2013 12:55 pm | ||
33,813 Registered Users
+12 new in 30 days!
