LakeEffects
Posts: 38 |
Prior to the last update of the beta, I could apply filters to any size image. Now, it just stops responding. When I check, all I can do is Force Quit. The error message returned is this:
Could not complete the Filter Forge 4 command because of a problem with the filter module interface. I'm on Mac 10.8 using the latest update of 4.003. The filter I'm trying to use is Paint HDRtist. It works ok with a small PSD (6x4" 300ppi) or small jpeg, but not a normal sized PSD file (13x9" 300ppi). This is a definite change from the previous version of the beta. Just to test, I also used this same PSD file with the watercolor filter and no problem. Any ideas? (I'm not technically knowledgeable about how filters work!) TIA! DebraS |
| Posted: April 4, 2013 6:53 pm | ||
Hello, have you installed the latest hotfix that is available in this thread?
When is that it happens? I mean, what do you do just before it happens, and is this using the reduced view, or actual view, or when you want to render the final result to save it? For me it works right (without the hotfix) , BUT I have Windows 7 and so it´s not the same |
| Posted: April 4, 2013 8:22 pm | ||
LakeEffects
Posts: 38 |
Going to check out the hotfix. . . thanks! [edit: Nope, that didn't do it. I'll post if I run into this with other filters. Off to try!]
Everything seems fine, the view is great and I can make new preset versions. When I hit apply to render it, NOTHING happens. It's not until I wonder where it went and go check the icon that it says FF is non-responsive and must be force quit. After I force quit, then the filter module interface error shows up. It never goes into render mode. DebraS |
| Posted: April 4, 2013 8:30 pm | ||
