xirja
Trying to get something like this:
| Posted: March 20, 2013 3:52 pm | ||||
Just hook up the color node and select white. Anything else? (I guess you ran into the image limitations in the forum)
| Posted: March 20, 2013 4:07 pm | ||||
xirja
Using the Solid Fill mode technique as seen in both: Cell Area Local Vortecies So far, I have this: ![]() _____________________________________________________
| Posted: March 20, 2013 4:24 pm | ||||
xirja
But how to fix the boundary between the curves, i.e. what sort of curve needed to attach to the gradient?
Also, it would be nice to be able to 'squarify' to get: a2SprialBorderTest.ffxml _____________________________________________________
| Posted: March 20, 2013 4:36 pm | ||||
xirja
Looking to further this along the lines of:
http://en.wikipedia.org/wiki/Navierâ€...Turbulence _____________________________________________________
| Posted: March 20, 2013 4:40 pm | ||||
I don't quite follow what you're trying to achieve. Maybe a photoshop approximation of the intended results?
| Posted: March 20, 2013 5:22 pm | ||||
xirja
So, I have 3 goals:
1. To get the bulge smoothed between the spirals (using the above ffxml attachment), so that the 2nd graphic looks like the 1st with respect to the transition between spirals 2. To be able to 'squarify' the same filter to achieve the 3rd graphic with respect to the general squared morphology. I know about masking and coloring, etc. 3. To then be able to move beyond the square grid of vortex centers and have a smooth iterative flow. Thinking about smoke stream eddies. _____________________________________________________
| Posted: March 20, 2013 6:42 pm | ||||
xirja
As close as I can get:
| Posted: March 20, 2013 7:43 pm | ||||
xirja
#2
xirja
Would hate to submit this with such glaring imperfections.
a2SprialBorderTest2.ffxml _____________________________________________________
| Posted: March 20, 2013 7:44 pm | ||||
xirja
Having some fun altering the boundaries for some ornamentation though:
| Posted: March 21, 2013 9:45 am | ||||
xirja
Using the last ffxml attachment, these areas circled in red are the problems I am looking to straighten/smooth (preferably with a curve and not a blur) to look like the very first graphic in this post:
| Posted: March 22, 2013 6:38 pm | ||||
xirja
Undulating areas more clear to see in the 'squarified' version:
| Posted: March 22, 2013 6:39 pm | ||||
xirja
Prior fun with altered boundaries using this filter:
| Posted: March 22, 2013 6:51 pm | ||||
xirja
oh, and if the ffxml examples are unloadable, they were made in FF4.0 Beta 1&2.
| Posted: March 22, 2013 7:05 pm | ||||
I'm not sure what all that stuff feeding into the bomber was doing... In my method, the circles work fine. The diamonds have little squares at the connections, which come from the gradient we're rotating. See what I mean (FF4 Beta):
SpiralBorderI.ffxml |
| Posted: March 23, 2013 8:22 am | ||||
xirja
That method is great for constant connected spirals.
The logic for the tint color was so that there would be counter rotation and amplitude differences based upon the distance from the center line. Thinking ahead about fluid dynamics emulation (a crude example):
Strangely using the bomber is 67% faster than using a blend(multiply) method. This might be one of those problems that can't be solved without relaxation of splines or something. See how noticeable the abrupt transition is on the loosely would spirals on the left? My only idea is to do an offset at the intersection points. ![]() _____________________________________________________
| Posted: March 23, 2013 4:16 pm | ||||
xirja
With the anticipated buildup of a overly dramatic 9 month pause,
Lol! Hahahaha! Rofl! Sorry, kinda slow sometimes, but better late than never eh? Oh what a baby! _____________________________________________________
| Posted: November 13, 2013 6:29 pm | ||||
xirja
Case closed I think! Thank you CFandM!
Sea Scrolls http://www.filterforge.com/filters/11851.html _____________________________________________________
| Posted: January 16, 2014 3:33 pm | ||||
33,814 Registered Users
+13 new in 30 days!
+27 new in 30 days!
