The VARIATION global variable in scripting is broken - it always contain the value 1, regardless of the variation slider setting.
While I'm at it - how do you add a variation input to a script that is influenced by the global variation variable (the same way as in noises etc)?
Quoted from the Scripting API help article:
API Variables
VARIATION – the value of the global Variation slider. Available only to scripts that have the Makes use of the global Variation setting flag turned on in their Script Settings.
Just add a regular IntSlider input and use it. You have to code the influence manually.
It wouldn't be broken if I forgot to set that option smile;-) I attached a filter so you can test it this time.
I'd like to see how you implement that IntSlider and Global Variation concept - I don't understand how you can mimic the general variation behavior this way.
Broken VARIATION.ffxml
Bionic
There's another bug here guys hence you cannot open file on first attempt from forum.
<class XFW::StateError> Unable to set rendering storage while rendering is in progress (rendering manager 04974968).
At a second attempt it would load fine, move file off your system Spinx & you'll see.
"Broken VARIATION.ffxml" must not be present in your filters and FF should be closed to reproduce this error.
Then click your own posted "Broken VARIATION.ffxml"
I generated a report for this error.
[ dump.txt ]
I didn't inspect the filter myself, but as the programmers tell me, you're returning the value of VARIATION as a color. It's an integer variable so when converted to a color it will have HDR values (1, 2, 3 etc.) If so, you should uncheck Filter > Anti-Aliasing > Clip HDR Before Averaging to make sure the result isn't getting clipped into the 0...1 range.
(Also make sure that the script you're outputting it from has HDR enabled in its Settings, otherwise you'll get clipping regardless of the value of "Clip HDR Before Averaging").
In the C++ code for FF components, we just XOR the global and local variation values to get the resulting seed. I'm not sure if Lua supports bitwise ops though (if so you may try adding or multiplying them).
Okay, that HDR clipping doubletricked me into believing it was the variation variable that was the culpritt when I tried to simplify the issue (and moreover it tricked me into believing it was reproduce).
The attached filter shows the real deal - the problem might not be variation but set_noise_seed or the get_noise function itself (it was in a more advanced version of this I ran into the problem):
Code
function prepare()
   set_noise_seed(VARIATION)
end;
function get_sample(x, y)
   local v = get_noise(x,y,1)
   return v,v,v,1
end;
VARIATION Issue.ffxml
I was able to render it perfectly fine, see the attached picture.
What is the problem?
Thanks for the variation explanation - for some unknown reason I thought you only applied global variation to components with no manual variation control hooked up, but I see its not the case (and it wouldn't make much sense either).
The problem is that changes to global variation don't affect the rendering smile:D
Yes, found it out later.
Here's the solution:
set_noise_seed(VARIATION + 1)
For some reason, it doesn't work when I pass VARIATION without adding 1 (or anything for that matter, like the local Variation setting). I'm assigning this to programmers.
Vladimir, does it count as a for-point bug report?
Bionic, we can't reproduce this error. Could you post detailed step-by-step instructions?
Vladimir and Bionic, "Unable to set rendering storage" is a long known issue that dates back to 2011.
We could not reproduce it using these instructions, so we're still waiting for a step-by-step from Bionic.
I am able to reproduce using 4.002 but not 4.003.
Bionic
Yep, that's the build I've used - 4.002.2758
I searched for similar issues and ended up with 2 old results - FF3.
You should be able to reproduce this using build 4.002.2758.
GMM, when I try to open this old post from CFandM dated 2011 I get a different error in FF 4.002.2758 Bug 2011
<class XFW::ArgumentError> No storage item with id = C:\Documents and Settings\CFandM\My Documents\My Pictures\Fuji Picts\Bugs\DSCF2288.jpg in DataExchangeStorage 0191FC40
I'll submit in case it's something new that can be fixed.
[ dump - CFandM dated 2011.txt ]
Bionic, can you reproduce it in 4.003?
Sphinx's submission about the VARIATION / VARIATION + 1 thing? Yes.
Bionic
Vladimir, errors from Sphinx and also CFandM are gone in 4.003 when opening their attachments.
Good. I'm closing the bug.
