lipebianc
FFF = Filter Forge Fan
Recently, I updated my filter "Image Mask Frame" and noticed that the small presets thumbnails (114x114) looked different from the actual thumbnails (512x512) on both website/application.
I don't know if that's only related to my filter, couldn't find other examples..
Filter => http://www.filterforge.com/filters/10853.html
I'm using FF 3.012 (Professional Edition)
Build: Filter Forge x86-SSE2 3.012.27269.23378 Release-SSE2, January 29, 2013 09:44
Windows 7 Ultimate SP1 (x64) / 8Gb Ram
Below, some examples for comparison (I enlarged the small thumbnails for a better comparison)
lipebianc
While the actual thumbnail render as expected, the small ones produced a different result smile:?:
Below, a comparison between the small thumbnails of the version I uploaded and the version I downloaded from the website:
lipebianc, will the thumbnails be identical if you enable Seamless tiling?
lipebianc
Seamless tiling is disabled by autodetection...
Clicking on any preset (on filter downloaded from the website) and simply adding it as a new one, renders the small thumbnail correctly (example below)
Should I re-submit this filter?
Yes.
I guess the filter was initially made some time ago in a previous Filter Forge version. The thumbnails were rendered and saved in that previous version, and when something has changed in a newer version the cached presets were used and not updated. I recommend you delete all presets, re-create them and resubmit your filter. This should cause the server thumbnails to update as well.
+12 new in 30 days!
