Check it out!
Here's the result of my sum script. it takes each pixel and adds up each pixel behind it. Of course I can't actually access pixel values because of the procedural nature, so I have to have a resolution slider that checks a percentage of the image back for each interval (kind of like percentage pixels).
Here I have taken the derivative of the result giving an (artifacted) original image!
Sum.ffxml Roses are #FF0000
| Posted: December 10, 2012 12:31 am | ||||
motion blurrrrr!!!!
| Posted: December 10, 2012 12:49 am | ||||
Hey wait a minute, this script can be used as an simple transform iterator.
| Posted: December 10, 2012 12:53 am | ||||
True indeed, however its speed at this stage is unusable.
Post some stuff you come up with! Roses are #FF0000
| Posted: December 10, 2012 1:43 am | ||||
holy crap does this mean you can use derivatives to undo real life motion blur (simple camera shake anyway)? oh my god next filter
| Posted: December 10, 2012 1:45 am | ||||
You basically need motion blur to be strictly linear and move in also a linear fashion with no ease in or out. XD
| Posted: December 10, 2012 3:35 am | ||||
Cool idea, and it works decently, but it's sooooooo slow. Comparatively, FF's built-in "derivative" component is very fast...I wonder why? What's the secret?
| Posted: December 11, 2012 12:25 am | ||||
Well the derivative component only needs two samples, whereas the sum script needs every sample until that pixel, racking up an enormous amount of loops and processing
| Posted: December 11, 2012 12:33 am | ||||
I used that principle in my variable blur.
Here is a boiled down version (filter does nothing, open up and see why Summed.ffxml |
| Posted: December 11, 2012 1:47 am | ||||
woah! I see a little black 1-pixel edge on the right and bottom side though
I see a little now how inujima's summed lookup table magic did fast variable blur, but still not completely! Math is so delicious Roses are #FF0000
| Posted: December 11, 2012 2:07 am | ||||
inujima
To be precise, it is offset 0.5 pixel. The cause of appearing of this black edge is that Blur radius is measured not from a center point of pixel but from a edge of the center pixel.
It needs Script component to get pixel size to fix this offset. (I have no idea to get pixel size without Script component.) Summed.ffxml |
| Posted: December 11, 2012 6:41 am | ||||
+12 new in 30 days!
13 unregistered users.
