Maybe is a checkbox in the regular slider control.
Is every bit a regular slider except has a -100 to 100 range that defaults to 0 in the center.
Useful for biasing or balancing and stuff like that. Gamma, exposure, offset, temperature, position, time, etc.
Yes, the Value control achieves this but it is also boundless and only appropriate in certain situations.
You mean Bi-polar sliders? smile:D +200
bump! smile8)
How about introducing Upper Limit and Lower Limit options to Value control components? Wouldn't that do the trick?
yes! that would be even better! smile:D
It could be implemented as a cosmetic option for the existing Slider control.
Also, there's no such thing in FF as "defaults to 0": it defaults to whatever the filter author specified in the default or other preset for this control (the only exception being the creation of a new Slider in the Editor).
A cosmetic option for the existing Slider control would be great.
That solution would also be more intuitive and "visually correct" than a range-limited Value control.
looks like he snagged that before you did Dilla smile;)
