I was checking some of the bugs that were fixed in this version and came across this one. I don't know if this is related to some of the other bugs that were already present or not. To reproduce grab this filter and edit the filter and go into the group. Select the Remapper on the Intslider. Move the offset to 1 and then move the step up.....You should get a crash with a nice message...
![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 24, 2012 8:08 am | ||
Here is the filter to use for this crash.....Submitting a report as well...
Init Switch Crash.ffxml Stupid things happen to computers for stupid reasons at stupid times! |
Posts: 3502 |
Thanks CFandM, this has been reported. I also see that the "Max Value is limited" note on the IntSlider gets trimmed.
| Posted: October 24, 2012 8:49 am | ||
Yep...Thanks Gmm, I was not sure if this one had been reported or not...
| Posted: October 24, 2012 11:26 am | ||
A similar int-slider bug. There's a lot of them, and I don't know if this one's new.
1. Edit the filter 2. Go into the group 3. Select the int-slider 4. Reduce the max value 5. Exit group The first bug (minor): 6. Raise the max value of the int-slider (you're out of the group now) 7. Notice the warning message underneath refers to the old max size, not the new one (also, the message is cut off) The second bug (major): 8. Try to increase the size slider past the new max value 9. FF crashes #Int1.ffxml |
| Posted: October 24, 2012 5:00 pm | ||
| Posted: October 24, 2012 5:01 pm | ||
I got that as well Indigo..Same error but different control value and range....Using your test filter.....Lots of bugs in that slider for sure....
| Posted: October 24, 2012 6:05 pm | ||
+12 new in 30 days!
11 unregistered users.
