Trying to install FF4, second time of trying to install, redownloaded etc. I can't install
Operating system: Windows (6.0 build 6002) Service Pack 2 Physical memory: 3068 MB Number of processors: 4, available: 4 Processor info: Intel® Core2 Quad CPU Q6600 @ 2.40GHz, ~2387 MHz Filter Forge x86 4.001.25805.53330 Release, September 12, 2012 12:45 [9/16/2012 8:52:34 PM AUS Eastern Standard Time] Exception caught at thread 00001EAC 'Application': <class XFW::Kernel::StdException> bad allocation <unknown file>(0) : <unknown function>()+0 at 0088BBA4 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0067EA1B in Filter Forge x86.exe <unknown file>(0) : GetProcAddress()+451 at 75C4941E in C:\Windows\system32\kernel32.dll <unknown file>(0) : <unknown function>()+0 at 00EC5125 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00F4C0E4 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00891151 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0069C6C5 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0088B868 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0088959D in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0088D437 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00672ACC in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00528136 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 005272D7 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00893E80 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0054E277 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0040F7DB in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0089507F in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00898D87 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00893E80 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 00894E5A in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 0089B264 in Filter Forge x86.exe <unknown file>(0) : <unknown function>()+0 at 008B1333 in Filter Forge x86.exe <unknown file>(0) : BaseThreadInitThunk()+18 at 75C4D309 in C:\Windows\system32\kernel32.dll <unknown file>(0) : RtlInitializeExceptionChain()+99 at 77531603 in C:\Windows\system32\ntdll.dll <unknown file>(0) : RtlInitializeExceptionChain()+54 at 775315D6 in C:\Windows\system32\ntdll.dll CONTEXT_CONTROL: CS:EIP 001B:75C3FC56, SS:ESP 0023:00129DC4, EBP 00129E14, FLAGS 00200212 CONTEXT_INTEGER: EAX 00129DC4, EBX 00000000, ECX 00000003, EDX 00000000, ESI 00B221A4, EDI 00129E54 CONTEXT_SEGMENTS: DS 0023, ES 0023, FS 003B, GS 0000 |
| Posted: September 16, 2012 6:28 am | ||||||
Carl is alive!
| Posted: September 16, 2012 6:34 am | ||||||
| Posted: September 18, 2012 4:31 am | ||||||
Obviously I seem to be the only person who can not install FF4, ... FF team, volunteers, auxiliary staff ....... anyone?
| Posted: September 18, 2012 4:34 am | ||||||
Can't help in the install department, but I'm gonna stick around for the duration of the beta, which should result in lots of "short time no speak".
| Posted: September 18, 2012 4:45 am | ||||||
Posts: 3502 |
Well, this exception is thrown by Filter Forge, not by the installer, so I guess you've installed everything correctly.
Do you start FF as a standalone or as a plugin? Please go to the 'Filter Forge 4\Bin' folder and double-click the 'Filter Forge x86.exe' file -- will it work? |
| Posted: September 18, 2012 5:02 am | ||||||
GMM tried FFx86 file, same thing as previous trying to launch free standing and as plugin in ps cs5, according to the task mamnager it's ticking away at a very low 1-3% cpu ..... gets to 1,659,936 k in the memory and everything stops, no cpu usage
Dilla, rewording [ but only to put words in your mouth ] what you're saying is that you will be making many many new filter for public consumption |
| Posted: September 18, 2012 6:20 am | ||||||
| Posted: September 18, 2012 7:13 am | ||||||
A couple maybe. There is one filter in particular that I'd really like to make, but I'm not going to say which (I've posted about it in the User Gallery section a long time ago). --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: September 18, 2012 7:34 am | ||||||
Heres a shot in the dark but uninstall FF then go to the C:\Users\YOUR USER NAME\AppData\Roaming and delete the Filter Forge4 folder...Then when you install DO NOT IMPORT anything.......Maybe perhaps for some reason a filter is preventing FF from opening.....
| Posted: September 18, 2012 12:42 pm | ||||||
look forward to what you dream up
your a winner bullseye ............ there needs to be an import filters button,under filters in the gui, unless I'm just not seeing that feature somewhere. Great thinking CF |
| Posted: September 19, 2012 2:45 am | ||||||
manually adding the files caused the repeat of the problem ....... I have about 400 library filters, ummm and about 4800 odd of filters in My Filters folder. Is the volume of filters the problem or specific filter?
| Posted: September 19, 2012 3:15 am | ||||||
Glad that one worked for ya Carl..
| Posted: September 19, 2012 6:36 am | ||||||
Posts: 3502 |
Thanks CfandM, you've actually written everything I was about to suggest. Removing the filters and adding them back in stages should locate the culprit.
| Posted: September 19, 2012 7:06 am | ||||||
hehe yep..Great Minds..You know the rest... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: September 19, 2012 8:44 am | ||||||
well it isn't any filter causing the problem it's the quantity, the bug is in the import filters
| Posted: September 22, 2012 3:56 am | ||||||
