| Gene S Morgan | ||||
| Posted: August 27, 2012 9:15 pm | ||||
| Posted: August 27, 2012 9:19 pm | ||||
Just played with this one, it's really fun
I like how you have the layering effect |
| Posted: August 28, 2012 2:27 am | ||||
Thanks for your comments and glad you like it.
well you fill the stripes with whatever you want and can be used through the color control input so feel free to use any kind of textures, patterns, images and whatever you may think that could be used. Also you can make different combinations with the first layer grid, the second in the back and the background image on the far back. And even you can use after another another full image with transparency over the top and use this as a background alone, I will see if I can add also this feature to the filter. |
| Posted: August 28, 2012 12:46 pm | ||||
WOW!!!
I have just seen in my email that this filter has got an HU award !!!
This is my second HU and want to thank very much to all the ones that have been using it and like very much that this filter has been useful for you and works good for what you may be using would be good and nice to see some examples of what this has been used for Here is something I have built from 5 different source images ( 4 images added on the settings and the background with the main "File-->open image") and using 2 stripes (2 or 4 stripes unchecked) and using the default preset 1 |
| Posted: March 20, 2013 6:23 am | ||||
The bad thing on using the color controls inside the settings panel is that you can´t try different combinations and presets, as once you load your own images on one preset and change to another preset, all the images are changed to the presets filter images instead
This does happen on ALL the filter forge filters the uses color control in settings and not only in this one another example using preset 10 |
| Posted: March 20, 2013 6:52 am | ||||
After I have seen the news of that I have got a HU award for this filter (thanks very much again and glad that is useful) I have thought that this could be done even better and have more options and be able to choose if you want to activate or desactivate any of the four images available, and have also alpha channel background if possible.
Here is another example with the settings of preset 2 |
| Posted: March 20, 2013 7:02 am | ||||
Janeway
This is great, I like it!
| Posted: August 3, 2017 4:15 pm | ||||
Thanks Janeway, glad that you like it
This filter could have many different ways to use it, and you could load weird and curious images inside the strips All over internet there are already many examples of art made with photos cut into strips and the using waves woven crossed Some examples in this google search images Although there are many more |
| Posted: August 9, 2017 8:23 am | ||||
Janeway
Thanks for the link. There are a lot of possibility in this filter.
| Posted: August 14, 2017 11:13 pm | ||||
12 unregistered users.
