Jillene
Posts: 4 |
Window 7; Photoshop CS664 bit
FF3 freezes computer and does not fully launch when selected from filter drop down from within photoshop CS6 (plugin) have to stop FF process from task menu to unfreeze. Generates this error code Error: ClassVFW::0SCALLERROR,writefile(block4, childpip 000000214, master pipe OSA68F0 error code OxOOOOOOE8. progressively worse. FF3 does work in stand-alone mode. Rebooting PS or system used to correct the issue now it will not. Please advise. |
| Posted: August 19, 2012 12:18 pm | ||
Posts: 3502 |
Do you use Comodo or similar AV products?
| Posted: August 20, 2012 3:35 am | ||
Jillene
Posts: 4 |
No I do not use Comodo or any other similar AV product. This started occurring with Photoshop CS 6 and is in consistent. In the past, re-starting photoshop would solve the issue for a couple weeks. However, this time, restarting photoshop or even rebooting my computer will not clear the problem.
| Posted: August 20, 2012 5:34 pm | ||
I think that the best thing you can is send the bug report that is shown when you get the error and so they FF support can see it better and you will get an answer soon by email with a possible fix or solution if there is one.
You have to explain exactly what are you doing, and what kind of image you are trying to load into FF from Photoshop. Does it happen with ALL the images and always? |
| Posted: August 21, 2012 3:51 am | ||
Posts: 3502 |
Snook, please reboot into Safe mode and check if Filter Forge would run in the Safe mode.
| Posted: August 21, 2012 6:26 am | ||
