Login - Create Account
Bookmark and Share
Gosper Island Challenge
not uberfez
Pretty simple fractal... (it seems)
http://mathworld.wolfram.com/GosperIsland.html
http://www.wolframalpha.com/input/?i=Gosper+island
http://library.thinkquest.org/26242/full/fm/fm11.html
BTW there's some numbers you need...
Scaling: 0.377964473
Rotation: 0.0530739038
This is as close as I've gotten...
Filters: 92
So we're looking at this transformation, repeatedly, correct?
(Image made in Illustrator)
not uberfez
Yup
Filters: 92
Look familiar?
Filters: 92
That 6-slice rotation gives us some problems. Of course, if we wanted just the outline of the shape, it wouldn't be a problem. But who wouldn't want to stick an image into the tiles? smile:|
not uberfez
Nice job. Once again brilliant minds come to the same conclusion. smile:D
This effect probably isn't as interesting as the fractal tessellation or hyperbolic tiling but I'm still obsessed with it.
I like it and is well done, although as said it would be better with some colors or textures.
not uberfez
You like everything SR... smile;)
not uberfez
I'm thinking we need our rotation map to look something similar to this...
Filters: 92
I believe the problem is that the rotation map gets more complex on each iteration. The easier handling is to duplicate the six-hexagon pattern to both sides (depending on the orientation of your rotation map) so when we use the rotation, the pattern copies fill in the blanks instead of transparency. Not the most efficient of approaches, but it should work.
Filters: 92
5th iteration with the fill-in technique.
I do not like everything smile:D , I like well done, beautiful and quality things as most of the things that you make that for me are really good, curious and interesting, and I do not like all filters at all. smile:D
Filters: 92
I got it working up to 8th iteration. At these render sizes you don't see much difference after the 6th.
(8 iterations + antialiasing + old laptop = slow bullet)
Unless my computer blows up before it, I'll post 7th iteration with 9x9 antialiasing.
I mean it literally: This old laptop overheats and shuts itself off if I run it close to 100% CPU for any extended periods.
not uberfez
Nice work ThreeDee but there aren't supposed to be holes. smile8)
Filters: 92
7th iteration. (I tossed the outlines.)
Looks like lace to me.
What could be really cool looking is if one were to modify this into a height map so that the black portions (expect for the outside) were high, white low, and the resulting "tower" height was proportional to their size. Then make it a displacement map in a 3D program. Perhaps I'll try that...
Filters: 92
I think it looks way more interesting with holes. smile;)
Filters: 92
This is one of those fractals that you could do one of those hypnotic infinite zoom animations with.
What would be good is to see this fractal enlarged and zoomed in to see it better.
Nice work ThreeDee but there aren't supposed to be holes. smile8) )
I think also that it looks much more interesting with holes
15,510 Registered Users
+7 new last day!
+55 new last day!
10,191 Topics
+10 new last day!
Totte, Skybase, 6 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
