Login - Create Account
Bookmark and Share
Camera Perspectiva by Morgantao (make a room with your own images)
Threedee have made this thread Off the Deep End with ThreeDee
On this page 4 of the link
SpaceRay wrote
On the first page, ThreeDee have shown this beautiful and well done tiling without any distortion that looks like a room filled with the tiled image
How would you make this ? Is there a filter already that can make this ?
Then Morgantao have put this
I'm pretty sure this can be done with just 30% of the components, but here's my take on it.
I only had about an hour to work on this, as my computer needs to be painted blue and dumped in the sea so there arent any real controls.
And he uploaded a filter with exactly this and have taken the time to make it even having his computer working badly which I appreciate much and thanks him very much for this
WOW!! He have done it and perfectly well, exactly the same as the example shown by ThreeDee and work wonderfully.
Here is his own version
Camera Perspectiva u1h.ffxml
Then after I have made an updated version of his great work and excellent work making this wonderful and simple filter
Here attached below I have updated it a little putting
* the option to have 4 or 8 images in the walls (you must check or uncheck both boxes for it to work right)
* added some new controls, and a scale for the back wall (in case the image is not perfectly square)
* added some more presets.
Be aware that the controls are specific for 4 or 8, so if you are using the 8 version, you MUST use the 8 version controls.
Camera Perspectiva 8 or 4.ffxml
Then after I had the idea to make it also checkered from an example I have seen with red and white squares and thought that it could be well done with this filter by Morgantao and could be updated to show this kind of checkered rooms.
So here it is with 45 presets as examples of what can be done (and much more making other different combinations)
If you fill all the color controls available with the same image you will have the same result as the filter above.
Also it would be possible to delete all the square of the same color in the checker pattern (for example all the white) in Photoshop and then in a layer below you could put another image or texture, so it could look that the room is in space or holed.
Here is the updated version for the checkered version
Camera Perspectiva 8 or 4 Checker.ffxml
Holodeck anyone? smile:D
And then after I have made some tests using the awesome Dungeons and Flagons by Mike Blackney made this examples shown here
Just make the result and then load it into this Morgantao´s filter
Or this one that shows only a short room so the tiles are not repeated like the ones above
and then I have made this other version with a free and public domain speakers image I found and after MAKING IT SQUARE I got this
15,398 Registered Users
+8 new last day!
+15 new last day!
10,106 Topics
+6 new in 7 days!
17 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
