Login - Create Account
Bookmark and Share
Image Mask Frame by lipebianc
http://filterforge.com/filters/10853.html
Cool and useful, awesome idea to make this.
At first looks like another frame filter, but then when you try it and use the settings is when this filter shines and show the great power and all the good things it really can do.
Very well done, with lots of customizable options to make grunge frames with lots of possible variations, and modify the mask as you want
And also have 3 ways of applying the frame to the source image toghether with the mask
The only problem is HOW FF manages the frames in all the filters that is forced to cut a part of the source image and does not "grow" outside of the image or you can´t add your beautiful and great effect as a frame already to the original image without cutting any part of the source as it happens on some Photoshop plugin filters.
The best solution for this problem is perhaps to not use the source image and make it transparent and make the frame as you want knowing that you have to make it at a resolution higher than your source image and then mix both inside Photoshop (or any other graphic software that could do this)
lipebianc
FFF = Filter Forge Fan
Thank you for your comments, SpaceRay.
Your input is really appreciated.
Yes! I'm aware of that!
I've been trying to figure some techniques to fix this, but no success smile:(
I couldn't really say that this issue is really FF's fault or my own flawed filter design. I'm not a FF expert, so maybe I missed a really basic/simple approach to the problem. smile:|
If you, FF gurus in this forum, have any suggestions on HOW to fix the described problem, I'd be very thankful smile:)
I do not want to put a negative note on your very well done and original idea, and is not my intention to do it, but must be known that someone could think that is an error from your filter, and is not you who made it wrong.
As far as I know, from all the frame filter I have seen, nobody has been able to solve this. I think that there is one frame filter that what is does is resize the source image to fit it inside the frame, but I think that this was a simple frame filter and not a complex like yours.
Carl wrote in the thread below
I'd like to point out no filter in the library that has a frame doesn't crop the edges of the image off.
If you are interested for more information there is some good explanation by Carl in this thread here
Film Noir by Carl
The link goes directly to the post related to this.
Filters: 70
You can use the Scale component to shrink the image to fit snugly inside the frame. Just use the same slider that controls frame width. You CAN'T keep the image the same size and add the frame around it because FF doesn't allow this.
BTW, nice filter! Using a second image to modify the shape of the frame is a cool idea! smile8)
"Time flies like an arrow; Fruit flies like a banana." -Groucho Marx
lipebianc
Thank you for your comments and help, guys.
I'll leave it as it is, for now.
I've submitted a 1st update that adds X and Y controls, as well as renamed controls, for a more intuitive approach ("INPUT" controls were renamed to "MASK").
Note that presets remains exactly the same smile:)
Filters: 91
Very nice example lipevianc ! Like this frame smile:)
Ghislaine @ http:3dscreensaver.t15.org
I agree that is better to leave it like this now and avoid possible problems with the scaling.
Nice example you have put lipebianc with that grunge frame.
Thanks for the update too.
annettep38
One of the best frames around. I'm enchanted.It is as gorgeous as the brush or noise filter, both of which I have adapted a bit !
It is fast too, which is much better than the smudge frame which takes ages.
Very cool filter. Allows for so many possiblities!
Mardar
Graphics Junkie
Filters: 53
Love this frame lipebianc. What I like best is you don't know what you are going to get until you add your image. A surprise in every image. Great job. smile;)
Filters: 74
very nice lipebianc smile8)
lipebianc
Thanks everyone for your kind words smile:) smile:) smile:)
2nd update - August/2012
- Now external images can be used a frame color A / B
- Added "INPUT Zoom Out" control for freely fitting your input image inside the frame (Most presets updated accordingly to demonstrate this feature)
- Added "INVERT Transparency" option (check Preset #4).
- Fixed a control inconsistency.
"INPUT Zoom Out" example below:
lipebianc
smile:!: (to preview this, "Transparent" checkbox must be *ON*)smile:!:
lipebianc
External images can now be used as frame colors A and B
Very well done and useful second update, will see how it works.
Thanks
Cool!
lipebianc
3rd update - February/2013
- New "MASK Invert", "MASK Contrast" and "Invert Grunge" controls added for more creative MASK tweaking possibilites.
- Description updated
- New Default Preset (previous is now preset #2)
- Some prestes sligthly changed
Example below:
1) Default Preset
2) Default Preset + Invert Grunge = ON
3) Default Preset + MASK Invert = ON
4) Default Preset + MASK Invert = ON + Invert Grunge = ON
Who are you?
Filters: 58
These look very nice! smile:D Well done!
lipebianc
Thank You, Skybase! Glad you liked it! smile:) smile;)
Below, an example of the "MASK Contrast" in action:
A) MASK Contrast = 0
B) MASK Contrast = 100
lipebianc
W O W!
I was just going to submit an update to this filter (that fixes an innofensive bug plus add one more nice feature) and found out this just went HU !!! smile:D
Totally unexpected!!! smile:ff:
Thanks everyone who found a good use for this!! smile:beer:
lipebianc
Congratulations and glad that you have got it AND I have to say that you realy deserve it much for having done this very creative, useful and awesome way of making frames in such a cool way
Way you say it was totally unexpected? as said, this is a really great, useful, easy and innovative way to make wonderful frames and is very well done, so I am not surprised at all that this have got an HU as surely this can be used much in many ways.
Thanks for making such good and awesome filters that you make that help much
15,400 Registered Users
+10 new last day!
+23 new last day!
10,106 Topics
+6 new in 7 days!
Recent Wiki Edits:
Follow filterforge on Twitter
