Login - Create Account
Bookmark and Share
GF Spirowires Maker v7 by Ghislaine
http://filterforge.com/filters/10850.html
WOW!! Like very much how you have combined your Spirowires into 4 multiple copies and make them work very beautifully !!
Is like a small kaleidoscope of Spirowires that gives great and nice results!
well done the mix to get some great new ways to multiple the wireframe Spirography into a new dimension of possibilities.
Thanks for the presets and surely this could have 80 nice presets instead of just 20
This below started from preset 11 and only moved the offset H
WOW!! I have just discovered that if you add a background IT INTERACTS WITH THE SPIROWIRE and it is also beautifully duplicated and works also like a small kaleidoscope to have even more possible creative and nice results.
Using the above one with preset 11, adding the FF window as background and changing some settings
Now Using the FF tree built-in that shows the branches of the tree follow the shape of the Spirowire in a nice way smile:)
Using the above one with preset 11, adding the FF tree as background and changing some settings
Using a background created with the great and awesome Smooth Stones Mosaic by uberzev and then loaded into this filter as background
using Preset 9 with settings changed and same uberzev“s background above that is available already in the link above and is this one shown here
smile8)
Hot
And as said I like much the presets you have done
here are 4 examples
Please, could there be another easier way for coloring the wireframes when using a background?, as is much more difficult to get the color you want, and sometimes is not possible at all. smile:(
Filters: 91
I go for lunch and I will study it and will come back
Ghislaine @ http:3dscreensaver.t15.org
Filters: 91
Do you mean that you want be able to change the wireframe color for the color you want when you have chosen a bg image ?
example
Filters: 91
same pattern with image as bg
Filters: 91
and the possibility to change for another color, here I changed the yellow for the green neon
Filters: 91
Please SR, it is a question above which needs an answer LOL
I am sorry I did not answer smile:blush: , YES, like your examples, you are right this is what I mean, be able to define the colors independently of the background choosen, specially light backgrounds
For example on this one shown here
I could only color it to white and not any other color that would look right.
Filters: 91
OK For this result, I had to change few things and also have added a level, so you will also be able to intervene on colors for more possibilities. I will update the filter today. But you have to know that these operations COULD change the bg designs.
OK, Thanks for making the update and be able to make it possible, I know that this COULD probably change the background designs, but is something bad would happen, I can keep a copy of your original version and then update and download the new version when available (not in a hurry at all)
Mardar
Graphics Junkie
Filters: 53
Another beauty Gigi. You are a busy lady. smile:love:
Filters: 91
Thanks Mardar. Yes... a very busy lady... since 3 days, I'm very occupied to write FAQ on a forum and the new modo gives us problems, so I keep an eye on this guy. This means that I have no time for FF, but in few days, I will. smile:)
Ooooh, that's a special one!
I love what you've done here with your spiro-kleido-wire-scope smile;)
Filters: 91
smile:) I have some more spiro.......... scope in my bank. But I did not uploaded it yet. but one of these days, I'll upload it.
And thx for your nice comments.
15,400 Registered Users
+10 new last day!
+16 new last day!
10,106 Topics
+6 new in 7 days!
21 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
