Davids
Yesterday I downloaded Filter Forge 3 Demo and installet in to Windows 7 64bit with Photoshop CS6 Plugin. But Filter Forge 3 will not open ...
I uninstall it, and reinstall it again with deactivated internet security / Firewall - without success. (I Run it also as Administrator.)
What I observed, it installs the Program in C:\Program Files (x86)\Filter Forge 3. Even the Photoshop plug in the correct folder. But there is nothing in C:\Users\%benutzer%\AppData\Roaming\ ???
Any thoughts?
Can you run it in stand alone mode?
Davids
No, there is no response ...
(Photoshop crashing when I choose FF from plugin filters and freezing up. I have to
go to the task manager to "kill" PS to get it to shut down.)
Davids
GMM, I read this Tread, the reason why I'll internet security suite (G Data) disabled. But it did not help.
Please add Filter Forge to the exclusions list instaed of disabling the security suite. Please also check if Filter Forge runs correctly in the Safe mode.
Davids
It does work in the Safe mode.
The exception filter at the security suite, I have since yesterday:
C:\Program Files (x86)\Filter Forge 3\Bin\Filter Forge.exe
And for Files:
But it does not work.
Davids
I do not know why, after I brought my sytem on the level of last week, Filter Forge is now working
Glad to know everything works for you, Davids.
For anyone who would read this in the future: if nothing happens when you start Filter Forge (no response as a standalone and host crashing when used as a plugin) this is a symptom of an external software preventing FF from running. You can check this if you reboot into the Safe mode and try running FF: if it runs correctly the issue is 100% caused by an antivirus, virus, debugger or another low-level software running at Windows startup and blocking FF. Period. There is no other cause. You can locate the culprit, uninstall it or complain to its developers – but we cannot help at all when the issue is caused by another software.
marco2
check this too if you run comodo : http://www.filterforge.com/forum/read...8&TID=9478
