Apples
Filters: 37
I recently got a new pc with Windows 7 and since that time Filterforge every couple of minutes scrolls the edit window with my nodes out of view.
For example I select a node, want to edit the values on the leftside and all of a sudden the cursor reaches BEHIND my edit attributes to the grid where the nodes are and acts like a pan movement.
Where ever I click none of the buttons react anymore it only thinks it needs to scroll.
Any clues how I can fix this?
May The Forge Be With You
weird and strange smile:?:
I do not know what may be happening, just something that I thought is that if you have tried to change and use another different mouse to see if this happens the same, or to take out the mouse you are using and put it back later so see if it is the same
What surface are you using for under the mouse ?
Perhaps none of this thing really matter to this problem, but just thought about this
Apples
Filters: 37
Hey SpaceRay,
Ty for your reply.
I use a wacom intuos 3 with a pen, and the buttons on the tablet itself i disabled, but the problem is still there.
Strangely enough if I wait some time it works again, but after a couple of minutes the scrolling starts over.
Same with pen or mouse.
+1 to SpaceRay: it's a hardware or a driver issue.
Thanks GMM, as you have experience with this, now I believe more that is something to do with the hardware, AND if you are using a Wacom Tablet even more, as there could be something in the tablet surface that could be acting wrongly and pulling the mouse cursor in this weird way.
You say that is the same with pen or mouse, BUT is the mouse the one included with the wacom tablet or is it one external from another brand ?
How you tried to take out the Wacom tablet and use a normal standard mouse
And as GMM said, are the drivers updated and the latest ones ?
