I know that the presets of the filters have included all the information needed to reproduce the saved effect of that filter, BUT what about the others options and settings that are ALSO included in the preset?
I mean that I have seen that is included in the preset
* Built-in image used
* External image used if the preset is your own and not from a factory preset
* All the settings used in the Settings tab
* Antialiasing settings that you have in that moment activated when creating the preset
* Lighting Settings of the Lightings tab
* Ambient Occlusion that you have configured in the Lighting tab when creating the preset
* Render Maps configuration
Does the filter presets STORE any other setting or configuration apart from the above ones I have already put?
Can the Presets be able to change any of the options inside the options configuration panel?
I think this is VERY IMPORTANT when making presets for speed and know what is really stored in that preset AND if the information stored is really needed and is the RIGHT setting correct. |
| Posted: July 10, 2012 3:35 pm |
Details
E-Mail
I think you pretty much nailed it in your list
Nothing from the options menu is stored in the presets. |
| Posted: July 10, 2012 4:50 pm |
Details
E-Mail
gavind
+1 on this.
Two for the Money |
| Posted: July 11, 2012 11:42 am |
Details
E-Mail
Who are you?
Yup, that's about right |
| Posted: July 11, 2012 1:35 pm |
Details
E-Mail
Thanks for the comments
So the problem here would be the Antialias (AA)and Ambient Oclusion (AO) settings that are by default in some filters when they are NOT really needed to get the effect made by the filter and is not an important and essential part of the filter
It would be as good thing if there could be an option in the FF Tools --> Options menu to override and desactivate always the AA and AO IF you want, and so all the filters that have presets with AA and AO will be desactivated automatically without having you to make it manually
Of course I know that this will harm and damage the results of some filters that really need much this options activated to work right, BUT IT´S YOUR CHOICE, so you can decide when you want AA or AO or both
As it is now all the presets are fixed and you CAN´T change any factory preset, so having an option that could overiride and automatically turn off the AA and AO would be very good to have |
| Posted: July 16, 2012 10:38 am |
Details
E-Mail
Who are you?
Like 2 or 3 people have suggested earlier in light of this: global anti-alias or whatever can be global on off switch. |
| Posted: July 16, 2012 10:57 am |
Details
E-Mail
| Quote |
Is this already included and available in FF 3.0 ???
Please, can you be so kind to tell me where is this option ?
I have already turned off the checkbox of "Anti-alias sources" in Tools ---> Options ---> Rendering
BUT this seems that is NOT an option to turn off ALWAYS the Antialias, as I have checked that it is STILL working in the same way as before, and in all the presets that have stored the AA is STILL active and working in the same way, and unless you turn off MANUALLY the AA in Filters ---> Anti-aliasing you will still render the presets WITH AA.
AND then if you turn off the AA in Filters ---> Anti-aliasing, as soon as you click on a new preset that have stored the AA active, then this is turned on and activated AGAIN and you have to manually go and turn it off again, and so is the same with EACH one of the presets that have AA included.
Please, Please, if anyone knows a way that could be NOT applied Anti-alias when you click on a preset WITHOUT having to turn off each time the AA in Filters ---> Anti-aliasing it will be very welcomed
Thanks very much for your help |
| Posted: July 16, 2012 5:57 pm |
Details
E-Mail
What Skybase ment was that it's a feature that was requested before. others also want the option to globaly turn AO and AA off, as opposed to per preset manualy turning off.
This is not a feature that exists in FF3.
Hopefully will be in FF4, maybe, togather with setting locks |
| Posted: July 16, 2012 6:13 pm |
Details
E-Mail
Who are you?
Yeah AA-sources is a different function, has nothing to do with globally disabling or enabling it.
Just a simple button on the filter window would be nice.
HOWEVER, for AO there would be a need for something more specific since the settings there reflect that of the scene. So as an author, I would prefer that you keep the AO settings as-is and just render with or without it since I may have specific things happening based on the AO. If there are global settings for AO, then the whole thing can look ugly and hence people would disable it and my filter would look different as an end product. This goes with AA since sometimes I do use larger samples for certain situations. Very very specific with these settings. Most people just don't care enough to even touch them aside from turing them on or off heh. |
| Posted: July 16, 2012 7:04 pm |
Details
E-Mail
Thanks for the comments and sorry for the confusion
I agree that would be very good to have an option for a global and total turn off of AA if you want to have it this way so this could speed up much the render time, and you can decide if you justify the possible increase in quality.
| Quote |
I am very sorry that I do not have any hope that will happen in FF 4.0.
Regretably it seems that FF only adds what they want, and LOTS of useful and interesting requests and suggestion have already been done in FF 2.0 Beta and also in FF 3.0 and then they have NOT been included, so I fear the worse that in FF 4.0 lots of important and needed things will not be included if FF does not think that they are worth or they want to put them. |
| Posted: July 16, 2012 7:18 pm |
Details
E-Mail
