Login - Create Account
Bookmark and Share
GIMP and FF?
Filters: 70
Can Filter Forge run as a plug-in for GIMP [v2.8]? GIMP does not recognize the .8bf filetype. I don't have much experience with this stuff.
"Time flies like an arrow; Fruit flies like a banana." -Groucho Marx
There is a list somewhere where is put what software is supported as host for filter Forge, but I do not remember where is it. I do not know if Gimp is included in it, but perhaps if you copy the plugin and it does not work probably is not compatible, ALTHOUGH I think that Rod_D said something about a workaround trick to put plugins in Gimp, or maybe I am wrong.
Filters: 97
are you sure gimp doesnt accept .8bf's? i used it a long time back and i thought it did, but maybe that was just gimpshop and not gimp.
I think I found the Rod_D information about adding Photoshop plugins to GIMP, you can see it in this link here
Rod_D wrote:
So if you are interested in running 8bf's through your GIMP, let me know and i'll show you how to set up PSPI.
Which is a small plug-in that helps them run on GIMP.
Filters: 97
ah! that's good news!
Yep, GIMP doesn't natively work with .8bf plugins, but you can use PSPI in GIMP to enable them.
15,374 Registered Users
+7 new last day!
+101 new in 7 days!
10,102 Topics
+16 new in 7 days!
Recent Wiki Edits:
Follow filterforge on Twitter
