Login - Create Account
Bookmark and Share
Wooden wall by dactilardesign
http://www.filterforge.com/filters/10743.html
This looks really good.
Only thing I think you should fix is the continues texture.
In reality, you'll probably never see two planks, or tiles have the knot aligned.
Look at some of the other wood floors and parquet filters and see how to fix this. Then it would be total awsomeness! smile:)
dactilardesign
Yes, you are right.
If you decrease the branch scale and maybe amount, you get a more realistic look with less chance to get a knot shared by two planks.
But I will try to make a mask to avoid that anyway.
Working on the update.
dactilardesign
Uploading update.
Now the filter mixes two different knot sources, but the mask is not perfect, and you may get shared knots sometimes. Just play with the "knot mask variation" control to avoid that.
That mask will mix also the wood texture, so now you have a more random base wood texture.
Finally, added a row shift control to the filter.
There's a slightly less complex way to achieve this.
In the top two Tiles components of your filter (color and grayscale), change the Fill Mode from Normal to Jumble.
It's also not a 100% guarentee that no knots will be shared, but it's easy to do smile:)
dactilardesign
lol you are right.
Now mixing both ways, it's really hard to get shared knots.
Thank you for helping me to improve the filter Morgantao.
(now we have to wait for the first update to be published).
I know what you mean, I have an update waiting to be updated too smile:D
dactilardesign
Updates online!
Enjoy smile:)
dactilardesign
New update.
Better normal and bump, there was a mistake in the filter tree.
Gerbrand
Nice Filter but it's somewhat restrictive in a way that the wooden wall consists of
minimal 2 components. It would be perfect if the wooden shelves are running smoothly
from top to bottom without interruption. In that way the filter would be more universal usable.
I do hope an update will fix that in the near future.
dactilardesign
The restriction is not a filter one, is the pattern generator this filter uses at it's origin.
I will try to find a solution.
Filters: 59
Lovely weathering detail! My new favorite wood. smile:)
dactilardesign
Thank you. Updating the filter when I get an updated license (still with FF2)
dactilardesign
It can be done by increasing (a lot) the complexity of the filter, but I think it's ot worth it since you can find a turnaround rendering at twice the resolution and then cutting.
Maybe FF4 allows a brick pattern which would lead to a single vertical plank. FF2 does not.
15,411 Registered Users
+10 new last day!
+22 new last day!
10,110 Topics
Totte, 22 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
