Login - Create Account
Bookmark and Share
Be able to copy the settings of a component and paste it into another
I have seen that sometimes you have to repeat the same component between 5 and 10 times and it must have all the same settings, well this is easy if you just have started, so you make the first one, and then with copy and paste this same component you get it duplicated with the same settings.
BUT what happens if after when it is linked to others components and you want to changed all the settings again in the similar components?
This is why I am suggesting to be able to have a "COPY COMPONENT SETTINGS" and be able to "PASTE COMPONENT SETTINGS" to all the other same components and so have all the same easily without having to do it manually one by one.
This is specially important on more complex components with many settings, like for example the BOMBER.
Of course that this could be ONLY possible if you copy the components of for example the bomber, and then you would only be able to paste the settings to another bomber component and would not be possible to use this on other components, as all have they own settings.
not uberfez
I've been meaning to start a thread on this. I'd call it something like "Paste With Inputs Connected" for lack of a better term.
15,375 Registered Users
+8 new last day!
+5 new last day!
10,102 Topics
+16 new in 7 days!
21 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
