Opitcal Chaos 2 by Skybase http://filterforge.com/filters/10714.html |
| Posted: June 5, 2012 8:44 am | ||||
good and well done, although you should include a warning, do not use this if you do not have available pills for headaches Or also another warning, "do not use for more than 15 minutes" Also, please, could you be so kind to tell me what an OPITCAL is ? Perhaps OPITCAL means that if you use for too long you will need to go to the OPITAL, sorry, HOSPITAL
And here is one example I made |
| Posted: June 5, 2012 8:49 am | ||||
default presets design |
| Posted: June 5, 2012 9:00 am | ||||
Clever, wish I'd thought of it. |
| Posted: June 5, 2012 9:02 am | ||||
| Posted: June 5, 2012 9:15 am | ||||
and now the same in color |
| Posted: June 5, 2012 9:22 am | ||||
bigger detail so see better the great effect |
| Posted: June 5, 2012 9:23 am | ||||
and even bigger detail in real size of the same one above here |
| Posted: June 5, 2012 9:25 am | ||||
Nice filter Skybase, and also nice examples SR, but hard for my old eyes. |
| Posted: June 5, 2012 9:30 am | ||||
Just had a peek at how you did it, and I have to say it's WAY simpler than my version Also, my version works a little different... You can actually have 3 input images (one for mask, one for zig, one for zag), and you can switch directions of zig and zag. Both are easy to add to your version. Also, in my version you can have the lines at 0 and 90 degrees, or 45 and -45 degrees. Also easy to add to your version. Last thing, in my version there's transparency support. Here's an example of mine, with lifesaver as mask (with transparent BG), and two photos as colors, and at 0,90 degree form: |
| Posted: June 5, 2012 10:18 am | ||||
freaky deaky, skybase! i think even the pacman characters would get lost in this one If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: June 5, 2012 10:44 am | ||||
WOW! Morgantao your version looks also very good, and like much that you can mix images, and configure the zig and zag, and have 3 input images, you could upload it also to the library as it not exactly the same as the one from Skybase. | |||
| Posted: June 5, 2012 10:46 am | ||||
It's different, but honestly, the only reason I made this filter is because I saw the lifesaver example in Skybase's thread. I didn't know if he's going to release it, so I made my own. I don't want to release my version and take from Skybase's download and usage ratios (Unless it's with his blessing). And as I said in my previous post, all can be added by skybase to his filter as an upgrade, so it's totally his call. |
| Posted: June 5, 2012 1:51 pm | ||||
Just upload it somewhere. |
| Posted: June 5, 2012 5:27 pm | ||||
Does somewhere include the library? |
| Posted: June 8, 2012 2:05 am | ||||
I wouldn't care but if it gets bounced back just put it as an attachment. |
| Posted: June 8, 2012 5:44 am | ||||
Bounced back as in "your filter can't be added to the library because it is a ripoff"? |
| Posted: June 8, 2012 6:00 am | ||||
15,511 Registered Users
+8 new last day!
+59 new last day!
10,191 Topics
+10 new last day!
GMM, 13 unregistered users.
