MaryCodd
Posts: 5 |
Hi,
I bought Filter Forge 3.0 yesterday, installed it, and put in the license#. I can't download any filters. I've tried downloading from within FF3.0. I've tried going to the Filter Forge website and downloading from there with FireFox and Opera. I've tried using Photoshop CS5.5. FilterForge starts & says connecting to server. Immediately an error message pops up and the program crashes. The computer has to be restarted. Here's the error message:
The OS is Windows 7, with 16GB RAM, and 844 GB free on drive C: Any suggestions? Thanks. |
| Posted: April 19, 2012 5:59 pm | ||||||
Just to save you some time, email the same question to the support team.
Sometimes you can get the answer here on the forum, sometimes you have to get it from the support team. |
| Posted: April 19, 2012 6:27 pm | ||||||
MaryCodd
Posts: 5 |
Hi Morgantao,
Thanks for the suggestion. I already submitted bug reports, and emailed the support team. Since I haven't heard back I thought I'd try the forums, too. |
| Posted: April 19, 2012 6:30 pm | ||||||
I have had this error before the same like you and also thought that the problem was with the hard drive, but was not, BUT regrettably I do not remember what I have done to fix it. BUT there is something strange, and is the "InternetQueryOptionA(proxy settings)"
Are you using any Internet Software Security software that could be blocking FF ? What software are you using if any? I have only found on internet this here
Know that even when you have 16GB RAM, Filter Forge CAN´T use more than 1,5 GB. ALSO I have put a dedicated thread to solve and give help to possible download problems that you can see in this link here below http://filterforge.com/forum/read.php?FID=8&TID=9427 |
| Posted: April 19, 2012 7:51 pm | ||||||
MaryCodd
Posts: 5 |
Hi SpaceRay,
Thanks for your reply. Actually, I read your thread http://filterforge.com/forum/read.php?FID=8&TID=9427 before posting in the forums. I don't use Comodo IS, ZoneAlarm, or Spyware PC Doctor. I use McAfee AntiVirus Plus, and I haven't found anything in the forums saying that would cause a problem. Maybe it does with version Filter Forge 3? I haven't tried your last suggestion of uninstalling & reinstalling FilterForge yet. Since this is a brand new installation of Filter Forge and a pretty new computer, too, I thought that might not be necessary. If I don't get a solution here or from support by tomorrow, I'll try uninstalling and reinstalling the software. |
| Posted: April 19, 2012 8:21 pm | ||||||
Just know that the support team usualy doen't work weekends, so it may be that you'll get the response on monday.
| Posted: April 20, 2012 1:58 am | ||||||
Posts: 3507 |
MaryCold, do you use a proxied or a direct Internet connection?
Please delete the following file: %APPDATA%\Filter Forge 3\Options.xml and try again. |
| Posted: April 20, 2012 2:55 am | ||||||
MaryCodd
Posts: 5 |
Hi GMM,
I deleted %APPDATA%\Filter Forge 3\Options.xml and tried again. The same thing happened, same error message, and I had to restart the computer. proxydetect.com says I have:
I have a cable modem and wireless router and use fullchannel.net as my ISP. |
| Posted: April 20, 2012 10:02 am | ||||||
MaryCodd
Posts: 5 |
Problem solved...
Support suggested I reconfigure Filter Forge Options. Found here: Tools > Options > Online tab. Then try one of the following: 1. If you use a proxy server to connect to the Internet, choose the "Use proxy" option in the "Connection settings" area. 2. If you don't use proxy, choose "Direct connection" in the above settings. Despite the fact that proxydetect.com said I am using anonymous proxy, the "Use proxy" option in the "Connection settings" area didn't work. However, "Direct connection" does work. So now I am happily downloading filters! |
| Posted: April 20, 2012 11:04 am | ||||||
I cannot download filters. It says that you must be connecting to internet... but I am connected..
Help please. Is it a FF bug, anyway, this is not from my pc.visit https://gisoft.ca |
| Posted: June 25, 2012 9:00 am | ||||||
Benthaicreations
same troubleshooting here..I get the "Unable to connect to the server..."
cannot update or download any filters!! |
| Posted: June 25, 2012 9:07 am | ||||||
Yes exactly the same words that I had.
| Posted: June 25, 2012 9:16 am | ||||||
Posts: 3507 |
Users never sleep! Three posts within a 15-minute server downtime
| Posted: June 25, 2012 9:21 am | ||||||
| Posted: June 25, 2012 9:28 am | ||||||
| Posted: June 25, 2012 9:41 am | ||||||
33,860 Registered Users
17 unregistered users.
