I think that the best way to help the FF team and ourselves to be able to solve the mystery of why on some computers Filter Forge can´t render with higher resolutions is to put here a list of the bug reports that FF give and so FF team will be able to see what is happening.
Please if you are having problems and rendering errors with high resolution images, help us also with your own bug reports to help the FF team and ourselves to solve and fix this
GMM wrote:
joBox, your anger is useless unless you provide more details. What is your OS, it is 32-bit or 64-bit, do you use Filter Forge in the plugin mode (if yes - under which host app) and – the most important – what is the exact error message you get.
Yes, you are totally right, perhaps the important key to solving the mistery and fixing the possible bugs is to know EXACTLY WHEN AND HOW the error happens.
We must take not of every single error and make a FF bug report of each one, and note also which filter has been used and if it was in standalone or plugin mode, and under which host.
So having all this important information the FF team could really find and know what is happening and could be able to reproduce the errors themselves and be able to find the solution.
So thinking on all these things I think that I will make some tests and will take good note of any error I find and put it here in the forum to help the FF team.
I regret I did not take note of the many rendering errors I had before, but from now on I will do it and put it here and so it could be found a solution for this as really this is the only way to do it, because the FF team are not magicians or does not have the crystall ball to know what is happening if we do not give them the bug reports FF gives us.
I have tried to render a 4819 x 2825 JOG (not very high resolution) image and got this error I put below from the bug report
I get frequently similar errors like this
Any information of what is happening ?
ERROR BUG REPORT
The original bug report had 465.000 symbols, and the forum only allows 64.000 so I have reduced it much to put it here
Code
Operating system:  x64 Edition (6.1 build 7601) Service Pack 1
Physical memory: 16301 MB
Number of processors: 8, available: 8
Processor info: Intel® Core™ i7-2600K CPU @ 3.40GHz, ~3391 MHz
Filter Forge x86-SSE2 3.006.22568.34466 Release-SSE2, November 10, 2011 15:41 [29/01/2012 17:36:01 Romance Standard Time]
Exception reported at thread 00004FE8 'RenderingMgr 094C2838/0':
<class XFW::Kernel::StdException> bad allocation
Possible original exception location:
<unknown file>(0) : <unknown function>()+0 at 007EB384 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00773BD5 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0072D5DE in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00A76A41 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00A769DB in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0072D30C in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00AC4873 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00788F17 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006CF5F0 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 0070D379 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006D2BE0 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 006D2F6C in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 00786B8C in Filter Forge x86-SSE2.exe
<unknown file>(0) : BaseThreadInitThunk()+18 at 75A6339A in C:\Windows\syswow64\kernel32.dll
<unknown file>(0) : RtlInitializeExceptionChain()+54 at 77D49EC5 in C:\Windows\SysWOW64\ntdll.dll
<unknown file>(0) : <unknown function>()+0 at 00786A90 in Filter Forge x86-SSE2.exe
<unknown file>(0) : <unknown function>()+0 at 385743A8 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:3E61EF90, EBP 3E61EFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 3E61EF90, EBX 1157CCE8, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 3E61F020
Exception reported at thread 00004B10 'RenderingMgr 094C2838/3':
<unknown file>(0) : <unknown function>()+0 at 0402FC48 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5224EF90, EBP 5224EFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5224EF90, EBX 378D9178, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5224F020
Exception reported at thread 0000434C 'RenderingMgr 094C2838/5':
<unknown file>(0) : <unknown function>()+0 at 5A0EE7A0 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5248EF90, EBP 5248EFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5248EF90, EBX 3F639690, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5248F020
Exception reported at thread 00004FF4 'RenderingMgr 094C2838/6':
<unknown file>(0) : <unknown function>()+0 at 1C314CA8 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5CFFEF90, EBP 5CFFEFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5CFFEF90, EBX 145DA3D8, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5CFFF020
Exception reported at thread 00004CB4 'RenderingMgr 094C2838/7':
<unknown file>(0) : <unknown function>()+0 at 350B7B40 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5D0FEF90, EBP 5D0FEFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5D0FEF90, EBX 497D5678, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5D0FF020
Exception reported at thread 0000557C 'RenderingMgr 094C2838/4':
<unknown file>(0) : <unknown function>()+0 at 1059A948 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5234EF90, EBP 5234EFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5234EF90, EBX 09FD3C10, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5234F020
Exception reported at thread 00004BA8 'RenderingMgr 094C2838/2':
<unknown file>(0) : <unknown function>()+0 at 0FA30578 in Filter Forge x86-SSE2.exe
CONTEXT_CONTROL: CS:EIP 0023:767BB9BC, SS:ESP 002B:5214EF90, EBP 5214EFE0, FLAGS 00000216
CONTEXT_INTEGER: EAX 5214EF90, EBX 04025668, ECX 00000003, EDX 00000000, ESI 00B15704, EDI 5214F020
[FFXLib::RenderingManager] Rendering settings dump:
Seed: 165
Seamless: false
Optimize blur radius: true
Supersample explicit inputs: true
Output size: 4819x2835
Sampling rate: 1
Supersampling kernel: 2
Jitter: 0
Bruteforce: false
High precision bitmap: false
Blend with original image: true
[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@4A2B9D38
[FFXLib::RenderingManager] Failed rendering block dump:
Block origin: 2709;354
Root component: result
Progressive pass: 0
Exception caught at thread 00003D38 'Application':
I wanted to help FF solve in a better way this problem and have sent them many bug reports and wanted that others could also help but seems that nobody have posted any help here and I wonder if they have at least sent bug reports of the bad allocation error to the FF team so they could have more information and know how many persons are having this problem and are interested to solve it.
33,849 Registered Users
+7 new in 7 days!
15,392 Topics
+44 new in year!
