joBox
One of the reasons I bought FilterForge (lifetime updates) is because it touts HUGE resolutions up to 65536x65536.
I am here to say this is false advertising. Here's a list of filters than cannot render above 8000x8000, and I need 15000x15000. Concrete Plastastic Woeful Wood Decay Energy Filtration Ink Ghost Lost Letter Grass Muscle Fiber Crackles Lake Bed Odd Rock Rock Salt Cyber Circuits I'm SURE there are many more. I have continuously added this bug report since 2.0 to support and they say it's on the list. BUT IT DOESN'T GET FIXED. So, if a company advertises a feature and it isn't able to do it, is that false advertising? I say YES. FIX THIS DAMN BUG! |
| Posted: January 24, 2012 8:15 pm | ||||||||
You are right, I have also tried to use images of 12.000 x 9000 pixels and all give error and can´t render either in FF 2.0 or FF 3.0.
I have not tried all the filters but on the ones I have tried all give error and can´t render the final result at that very high resolution. Even with images of 6000 x 6000 gives also errors.
Yes, is true, FF is making false advertising when they say that you could make renders of images up to 65536x65536 with ANY FILTER available. Perhaps it could work for filters that generate the image INSIDE FF, and it does not depend on an external image.
This text comes from the features page but does not say wich filter they used to make it and if it involved an external image or was just a FF own generated image.
Sorry, but this is not the way to ask for this, I know you are angry and want it fixed but you should ask it in a better why Please, do you mind if I request if you could be so kind to tell the FF developers team to be so kind and would you mind and care about the users that wants to user higher resolutions and be able to fix this damm bug that has been there since FF 2.0? This a more polite way to ask for it If FF will care about it and will make something to fix it is another thing |
| Posted: January 25, 2012 12:14 am | ||||||||
I tried some of those on that list and have had no issues with them....Tried at 9000x9000,15000x15000 and 20000x20000.....I have the AA settings set to render "All Pixels" 25 samples.....I also turn my ram usage to 40% so I can still do other things while FF renders.... Also I am on a slow machine by todays standards....Only an Intel Dual core OCed at 3gig.... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 25, 2012 2:57 am | ||||||||
Posts: 3507 |
joBox, your anger is useless unless you provide more details. What is your OS, it is 32-bit or 64-bit, do you use Filter Forge in the plugin mode (if yes - under which host app) and – the most important – what is the exact error message you get.
| Posted: January 25, 2012 3:50 am | ||||||||
Meant to quote Here's a list of filters than cannot render above 8000x8000, and I need 15000x15000. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 25, 2012 4:16 am | ||||||||
GMM Yes, you are totally right, perhaps the important key to solving the mistery and fixing the possible bugs is to know EXACTLY WHEN AND HOW the error happens. And thanks very much CFandM for testing yourself in high resolutions and that you have NOT had problems. This are very good and interesting answers and from this I have made two new threads What is the relation between the resolution size and the FF filter ? http://www.filterforge.com/forum/read...5&TID=9370 High resolution rendering test bug report compilation inside here http://www.filterforge.com/forum/read...8&TID=9371 |
| Posted: January 25, 2012 9:11 am | ||||||||
joBox
GMM . . . here's my problem:
This has been a bug that has been around since 2.0. I have submitted ENDLESS bug reports to support (whenever it crashes), and get the canned response back, "Thanks for reporting this error. This is a known problem, the developers are working on it. We'll add your report to the statistics for this problem." each and every time. Did you see those 2 words?? For over a year it's a KNOWN PROBLEM. We don't need to figure out how it happened, or what system I'm on to reproduce the problem because it's KNOWN. SpaceRay, I've gone through the process of being nice & offering help, then begging, then pleading, then finally SNAPPING and posting on this forum. I understand that probably only .05% of the users render huge resolutions, so this is probably why support has put this bug on the back burner, BUT: If they tout huge resolutions as a feature and it doesn't work, either take it off the feature list or FIX IT. I bought the program SOLEY for this feature, so you can see why I'm aggravated. Imagine if you bought this program because of the seamless tile feature, then it didn't make seamless tiles. C'mon . . If you are interested in my first bug submission, here it is: >======= APPLICATION BUG REPORT ======= > >Operating system:Â x64 Edition (6.1 build 7601) Service Pack 1 >Physical memory: 18422 MB >Number of processors: 8, available: 8 >Processor info: Intel® Xeon® CPUÂ Â Â Â Â E5462Â @ 2.80GHz, ~2792 MHz > >Filter Forge x86-SSE2 3.001.20499.14850 Release-SSE2, April 28, 2011 13:02 [6/16/2011 9:03:08 PM Eastern Daylight Time] >Exception reported at thread 00002B2C 'RenderingMgr 0459FCA0/3': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0A41B3F0 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0AB3EF90, EBP 0AB3EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0AB3EF90, EBX 04462878, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0AB3F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 00001FEC 'RenderingMgr 0459FCA0/7': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0A3CFF90 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0AF3EF90, EBP 0AF3EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0AF3EF90, EBX 0604BC10, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0AF3F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 00002188 'RenderingMgr 0459FCA0/6': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 047088A0 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0AE3EF90, EBP 0AE3EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0AE3EF90, EBX 06068D18, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0AE3F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 000015B0 'RenderingMgr 0459FCA0/1': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 041D46A8 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0A93EF90, EBP 0A93EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0A93EF90, EBX 047C4450, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0A93F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 00002330 'RenderingMgr 0459FCA0/0': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 08B1A608 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0901EF90, EBP 0901EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0901EF90, EBX 0591DD58, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0901F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 00002A5C 'RenderingMgr 0459FCA0/4': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0987D2C8 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0AC3EF90, EBP 0AC3EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0AC3EF90, EBX 058815B8, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0AC3F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > >Exception reported at thread 00002914 'RenderingMgr 0459FCA0/2': ><class XFW::Kernel::StdException> bad allocation > >Possible original exception location: ><unknown file>(0) : <unknown function>()+0 at 007A6514 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00736CB5 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB5EE in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A33A11 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A339AB in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006FB31C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00A7DD73 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006DB689 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A27D0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 006A2B5C in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0074C117 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 0069F1C0 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 00749E2C in Filter Forge x86-SSE2.exe ><unknown file>(0) : BaseThreadInitThunk()+18 at 75C333CA in C:\Windows\syswow64\kernel32.dll ><unknown file>(0) : RtlInitializeExceptionChain()+54 at 77729EA5 in C:\Windows\SysWOW64\ntdll.dll ><unknown file>(0) : <unknown function>()+0 at 00749D30 in Filter Forge x86-SSE2.exe ><unknown file>(0) : <unknown function>()+0 at 04299FB0 in Filter Forge x86-SSE2.exe >CONTEXT_CONTROL: CS:EIP 0023:76E0B727, SS:ESP 002B:0AA3EF90, EBP 0AA3EFE0, FLAGS 00000216 >CONTEXT_INTEGER: EAX 0AA3EF90, EBX 092BB380, ECX 00000003, EDX 00000000, ESI 00AC89A4, EDI 0AA3F020 >CONTEXT_SEGMENTS: DS 002B, ES 002B, FS 0053, GS 002B > > >[FFXLib::RenderingManager] Failed filter dump: ><?xml version="1.0" encoding="utf-8"?> ><Filter> >Â Â Â <Components> >Â Â Â Â Â Â <Result id="result"> >Â Â Â Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â <FilterType value="0"/> >Â Â Â Â Â Â Â Â Â <Lighting> >Â Â Â Â Â Â Â Â Â Â Â Â <Height value="0.20000000000000001"/> >Â Â Â Â Â Â Â Â Â Â Â Â <Environment> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Source value="Entrance, Night"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Brightness value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Saturation value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Rotation value="73.630039658411889"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RotationAxis x="0.98396021063017813" y="0.16224933813654652" z="0.074144832394902466"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Environment> >Â Â Â Â Â Â Â Â Â Â Â Â <Ambience> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AmbientLight red="0" green="0" blue="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Shadowing value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <CurrentOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayDirections value="4"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <TraceDistance value="0.20000000000000001"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayJittering value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayBounce value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AvoidStreaks value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <DirectSamples value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ROQuality value="3"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </CurrentOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <CustomOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayDirections value="16"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <TraceDistance value="0.29999999999999999"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayJittering value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayBounce value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AvoidStreaks value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <DirectSamples value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ROQuality value="10"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </CustomOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ArtisticSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <BlackPoint value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Midtones value="0.5"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <WhitePoint value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </ArtisticSettings> >Â Â Â Â Â Â Â Â Â Â Â Â </Ambience> >Â Â Â Â Â Â Â Â Â Â Â Â <Light> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Color red="0.61627906976744184" green="0.33919235622859201" blue="0.33919235622859201"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Latitude value="56.427101593945139"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Longitude value="31.462257993153028"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AngularWidthIndex value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AffectDiffuseSpecular value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Light> >Â Â Â Â Â Â Â Â Â Â Â Â <Light> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Color red="1" green="1" blue="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Latitude value="204.82934658814958"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Longitude value="62.33490237299911"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AngularWidthIndex value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AffectDiffuseSpecular value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Light> >Â Â Â Â Â Â Â Â Â </Lighting> >Â Â Â Â Â Â </Result> >Â Â Â Â Â Â <Cells2 id="cells2 01"> >Â Â Â Â Â Â Â Â Â <Noise red="1" green="1" blue="1" alpha="1"/> >Â Â Â Â Â Â Â Â Â <Background red="0" green="0" blue="0" alpha="1"/> >Â Â Â Â Â Â Â Â Â <Roughness source="slidercontrol 02" value="0.14999999999999999"> >Â Â Â Â Â Â Â Â Â Â Â Â <Minimum value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â <Maximum value="1"/> >Â Â Â Â Â Â Â Â Â </Roughness> >Â Â Â Â Â Â Â Â Â <Contrast value="0.68999999999999995"/> >Â Â Â Â Â Â Â Â Â <Fo rmula value="0"/> >Â Â Â Â Â Â Â Â Â <Scale value="2.2000000000000002"/> >Â Â Â Â Â Â Â Â Â <Stretch value="0"/> >Â Â Â Â Â Â Â Â Â <VerticalStretch value="false"/> >Â Â Â Â Â Â Â Â Â <Smooth value="false"/> >Â Â Â Â Â Â Â Â Â <Flat value="false"/> >Â Â Â Â Â Â Â Â Â <SolidFill value="false"/> >Â Â Â Â Â Â Â Â Â <Details value="0.40000000000000002"/> >Â Â Â Â Â Â Â Â Â <Variation value="1"/> >Â Â Â Â Â Â Â Â Â <OctaveCurve value="0"/> >Â Â Â Â Â Â </Cells2> >Â Â Â Â Â Â <HighPass2 id="highpass2 01"> >Â Â Â Â Â Â Â Â Â <Source source="cells2 01"/> >Â Â Â Â Â Â Â Â Â <Radius value="0.13"/> >Â Â Â Â Â Â Â Â Â <Contrast source="slidercontrol 01" value="0.72999999999999998"> >Â Â Â Â Â Â Â Â Â Â Â Â <Minimum value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â <Maximum value="1"/> >Â Â Â Â Â Â Â Â Â </Contrast> >Â Â Â Â Â Â Â Â Â <Monochrome value="true"/> >Â Â Â Â Â Â </HighPass2> >Â Â Â Â Â Â <SliderControl id="slidercontrol 01"> >Â Â Â Â Â Â Â Â Â <Name value-en="Contrast"/> >Â Â Â Â Â Â Â Â Â <UseRemapping value="false"/> >Â Â Â Â Â Â Â Â Â <Value value="0.75"/> >Â Â Â Â Â Â >Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â <Name value-en="Roughness"/> >Â Â Â Â Â Â Â Â Â <UseRemapping value="false"/> >Â Â Â Â Â Â Â Â Â <Value value="0.11"/> >Â Â Â Â Â Â >Â Â Â </Components> >Â Â Â <Presets> >Â Â Â Â Â Â <DefaultPreset> >Â Â Â Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â <Lighting> >Â Â Â Â Â Â Â Â Â Â Â Â <Height value="0.20000000000000001"/> >Â Â Â Â Â Â Â Â Â Â Â Â <Environment> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Source value="Entrance, Night"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Brightness value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Saturation value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Rotation value="73.630039658411889"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RotationAxis x="0.98396021063017813" y="0.16224933813654652" z="0.074144832394902466"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Environment> >Â Â Â Â Â Â Â Â Â Â Â Â <Ambience> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AmbientLight red="0" green="0" blue="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Shadowing value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <CurrentOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayDirections value="4"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <TraceDistance value="0.20000000000000001"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayJittering value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayBounce value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AvoidStreaks value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <DirectSamples value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ROQuality value="3"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </CurrentOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <CustomOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayDirections value="16"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <TraceDistance value="0.29999999999999999"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayJittering value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <RayBounce value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AvoidStreaks value="true"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <DirectSamples value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ROQuality value="10"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </CustomOcclusionSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <ArtisticSettings> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <BlackPoint value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Midtones value="0.5"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <WhitePoint value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â </ArtisticSettings> >Â Â Â Â Â Â Â Â Â Â Â Â </Ambience> >Â Â Â Â Â Â Â Â Â Â Â Â <Light> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Color red="0.61627906976744184" green="0.33919235622859201" blue="0.33919235622859201"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Latitude value="56.427101593945139"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Longitude value="31.462257993153028"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AngularWidthIndex value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AffectDiffuseSpecular value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Light> >Â Â Â Â Â Â Â Â Â Â Â Â <Light> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Color red="1" green="1" blue="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Latitude value="204.82934658814958"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Longitude value="62.33490237299911"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AngularWidthIndex value="1"/> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <AffectDiffuseSpecular value="0"/> >Â Â Â Â Â Â Â Â Â Â Â Â </Light> >Â Â Â Â Â Â Â Â Â </Lighting> >Â Â Â Â Â Â Â Â Â <Controls> >Â Â Â Â Â Â Â Â Â Â Â Â <SliderControl id="slidercontrol 01"> >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Value value="0.75"/> >Â Â Â Â Â Â Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â <Value value="0.11"/> >Â Â Â Â Â Â Â Â Â Â Â Â >Â Â Â Â Â Â Â Â Â </Controls> >Â Â Â Â Â Â </DefaultPreset> >Â Â Â </Presets> ></Filter> > > >[FFXLib::RenderingManager] Rendering settings dump: >Size: 4704.69 >Seed: 7318 >Seamless: false >Optimize blur radius: true >Supersample explicit inputs: true >Output size: 15000x15000 >Sampling rate: 1 >Supersampling kernel: 2 >Jitter: 0 >Bruteforce: false >High precision bitmap: false >Blend with original image: true > >[FFXLib::RenderingManager] Rendering storage: <class FFX::PreviewRenderingStorage>@0568F4A0 > >[FFXLib::RenderingManager] Failed rendering block dump: >Block origin: 9216;512 >Root component: result >Progressive pass: 0 > >Exception caught at thread 00001FCC 'Application': ><class XFW::Kernel::StdException> bad allocation |
| Posted: January 25, 2012 10:18 am | ||||||||
joBox
CFandM,
Thank you for taking your time and looking into this on your system . . . I appreciate it! Support seems to know the answer . . . . they just aren't doing anything about it for some reason. My system is MORE than adequate: Windows 7 (64-bit) 8 core / 18GB of RAM So yeah, just wanted to drop you guys a line and say thanks to CFandM, SpaceRay, & GMM for trying to problem solve this . . . My anger at this broken feature still stands, though |
| Posted: January 25, 2012 10:33 am | ||||||||
I understand very much your anger and that you have kept asking for a fix for this since long time ago and FF Inc. does not listen to you, OR they listen but doesn´t/can´t do something about it.
Having 18 GB RAM is not important at all with FF as it can ONLY use 1,5 GB. Please joBox can you tell me how is configured your paging file size ? Do you have it in C: drive or in another different drive ? How big is your page file configuration ? If you want to know why I am asking this, please read this thread here ---> http://filterforge.com/forum/read.php?FID=8&TID=9394 |
| Posted: January 30, 2012 1:04 am | ||||||||
joBox
SpaceRay: Having 18 GB RAM is not important at all with FF as it can ONLY use 1,5 GB.
joBox: why, Why, WHY would FF limit the RAM to 1.5GB!?!?!? It's 2012, people have ALOT more RAM than they did in 2002!! Get with the times FF. I have 18GB of RAM ready and willing to chew through through your computations . . . c'mon! SpaceRay: Please joBox can you tell me how is configured your paging file size ? joBox: I am testing the page file size (fix) now and will report back with the results. SpaceRay: Do you have it in C: drive or in another different drive ? joBox: FF is installed on E:, but putting page file size on C: . . . I'm pointing temporary files to C: too. Will see what happens . . . SpaceRay: How big is your page file configuration ? joBox: 30GB so far, let's cross fingers Thanks! |
| Posted: January 30, 2012 9:24 pm | ||||||||
joBox, Thanks very much for all your data.
Why ONLY 1.5 GB ? Well on FF 1.0 back in 2006 they had a special custom memory manager made specially for FF that overrides any other memory controller, so it seems that even upgrading FF to 64 bit it would NOT work and would not use more memory. So the solution would be to change and update the FF custom memory manager to use more RAM and be able to benefit from the new computers that have much more RAM than in 2006. But I do not think that this is a simple thing, and probably would involve much work to do, and I do not think that FF Inc. will do it. Please this thread too ---> http://www.filterforge.com/forum/read...9&TID=9398 |
| Posted: January 30, 2012 9:47 pm | ||||||||
Please jobox, could you be so kind to test and confirm if you can use Filter Forge as a plugin of Photoshop (or another host) and see if you keep getting the same error ?
Thanks very much. WHY I AM ASKING YOU THIS ? Because I want to confirm if what I have discovered is true in all cases. I have found that in my case this ONLY happens in the standalone version !! I have got this error many times and with just a 2500x2500 photo
USING FILTER FORGE AS A PLUGIN OF PHOTOSHOP CS5 SOLVES THE PROBLEM !!! BUT then I have used the SAME photo with Filter Forge as a plugin inside Photoshop and using the same filter and same settings, AND DO NOT GET ANYMORE this error , So I am happy that at least I know that to fix this undesired and unwanted error I just need to use Filter Forge as plugin and this SOLVES the problem. |
| Posted: March 21, 2012 2:40 am | ||||||||
33,849 Registered Users
+7 new in 7 days!
15,392 Topics
+44 new in year!
