Please, I have some problems after upgrading to Filter Forge 3.0
I want to ask if you are getting any of this errors I have seen now in my Filter Forge 3.006 version.
Any help to solve this will be great. Thanks very much.
Also have got this other message smile:D
And also have some trouble to make FF to work
And when try to download more filters
And also the failure to download more filters getting the usual
"GETTING FAMILIES VERSIONS LIST" error
If you have a Windows PC (or a MAC with windows) have you seen this error message ? smile:D
If you have an Apple Macintosh, have you seen this error shown here ? smile:D
I know that the message will not appear like this in your mac, but please look at the text and imagine it is in your MacOS style.
Also after a high usage of filter forge I have got this error message.
After searching in google for a good filter cleaning machine to be able to clean my own Filter Forge Filters collection I have found these two:
http://www.greenfiltercleaningmachine.com/
http://www.sonicdryclean.com/
this is a real one Spaceray - when FF get "pleasure" out of errors smile:?:
Which filter gave you that error message Carl?
I think the error you got means that the author of the filter used a picture named "pleasure-[something]" as an input somewhere, and FF just couldn't find it on your system.
Look at the settings tab, there should be a control for loading your additional image file.
Yes, this is important to know what have happened.
I have had just this SAME ERROR that you have put, please see below the screenshot.
This time I was using the new preview of the "Panoramic Planets" filters by CFandM that he has posted in the forum, and is just a beta test preview. The screenshot is after clicking on the default first preset.
YES, I think you are right, and is true, FF tries to load the picture with that name and is not found on your computer.
YES, I my case with the "Panoramic Planets" there is a setting tab to load your own images to substitute the missing picture.
And to confirm that this happens because an error of loading I have the second screenshot with exactly the same filter, BUT now clicking on preset 2, and gives the same error, BUT with the Manhattan name.
Also a tip for this is that it puts "Loading EXTERNAL image...
WEIRD SCI-FI THEORY
Do you mean FF is trying to get pleasure showing errors ? smile;)
Well Perhaps FF have begun and tried by itself to learn to feel like humans, but regretably FF Inc. has not programmed the "feelings" part of the code and so it can´t find it.
BUT for this instead of "Loading external image" it should be "Loading external feeling" as shown in the screenshot below smile:D
Probably this has happened with some filter that someone could have uploaded and this filter had a very secret mission, and inside the filter was a hidden part that is only activated after installed inside your FF, and then this is loose and infects the FF code and transforms it to humanize FF and so it tries to search for pleasure.
FF is always working for you, and he want to have pleasure out of it smile:D
So this error could be solved when:
1 - FF INC. delete the parts of the program that tries to feel
2 - Install inside FF (or externallly) a module for feeling like humans
3 - You install another filter that has hidden inside the code needed for the file "pleasure" that FF needs and looks for and can´t find.
27 unregistered users.
