lmicha
Posts: 1 |
I am using a file size 1980 X 1320 and am checking the "seamless tiling" box under setting and am getting the following message. "Source image must have an integer aspect ration"
I don't know what this means, or how to deal with it, where to find it and where to put it. Please help me throught this mess. |
| Posted: August 25, 2011 12:10 pm | ||||||||
Hi Imicha and Welcome to our community.
I'm not sure but I think that images must have the same width and height, as a square image for seamless tile. Personally, I usually work with 600 x 600 because it takes to long for the render when images are bigger than that. After, I use another software for making my ajustments on images. visit https://gisoft.ca |
| Posted: August 25, 2011 12:55 pm | ||||||||
Posts: 3507 |
Not necessarily the same. To enable seamless tiling the ratio between the width and height must be an integer number. So a 500x1000 or a 2000x400 image will suffice. |
| Posted: August 29, 2011 3:02 am | ||||||||
GMM has put a link to this HELP page of Filter Forge
http://www.filterforge.com/more/help/...lters.html
He has put this in this another thread that tells about this http://www.filterforge.com/forum/read.php?TID=6863 AND best is descibed here and shown graphically Image Processing Aspect Ratio Lab Report http://www.efg2.com/Lab/ImageProcessi...tRatio.htm
This is not true as said by GMM is not needed that is the same size both sides
| Posted: August 29, 2011 2:57 pm | ||||||||
14 unregistered users.
