TomE
Posts: 5 |
I've updated my machine to Windows 8, and can't get FF3 to be stable under the new OS.
This is Filter Forge 3.011 Pro Edition. When reinstalling the installer completes and then throws an Application Error 0xe06d7363 at location 0x76204b32. The software runs, but always throws an error on every exit: Filter Forge x86-SSE2.exe Application Error The instruction at 0x00f31f3e referenced memory at 0x00000000. The memory could not be read. I've tried reinstalling, but I can't shake this problem. |
| Posted: February 6, 2013 6:37 am | ||
FilterForgePersonOfTheYear
Posts: 4 |
When you run the install, have you tried right clicking the executable, and select "run as administrator"? Not sure if it'll make a difference, but it's helped me with other problematic software installs (not related to FilterForge), in the past.
| Posted: February 6, 2013 7:43 am | ||
Posts: 3502 |
Does it happen with the Windows-8 compatible version?
| Posted: February 6, 2013 9:10 am | ||
TomE
Posts: 5 |
I'll soon find out!
Er... I missed there was a Windows 8 version. |
| Posted: February 6, 2013 5:13 pm | ||
TomE
Posts: 5 |
Actually no, the Windows 8 version gives a different set of numbers but also crashes on installation and exit from the interface.
"The instruction at 0x00ff1ae6 referenced memory at 0x00000011. The memory could not be read." Everything works perfectly inside the program, it's just when you close it. I only just uninstalled the older version, I'll try cleaning everything out from the file system next. |
| Posted: February 7, 2013 5:23 am | ||
TomE
Posts: 5 |
OK got it working. Could be I've got too many files called Filter Forge 3 Setup.exe in this folder and might have used the wrong one. Now it wants the new license code which is a good sign. No crashes.
Thanks. |
| Posted: February 7, 2013 5:37 am | ||
Liquid
Posts: 4 |
I get this same memory error and it crashes on me too. I have tried everything I can think of to fix it. I am going to try to dump everything filter forge off my system and see if that helps and try to start over.
| Posted: March 18, 2014 2:40 am | ||
Liquid
Posts: 4 |
I still cannot get filter forge 3 to work with windows 8 and photoshop Cs6
No matter what I do, I keep getting this <class XFW::ArgumentError> The handle 009CB040 is not a valid window handle. This is so frustrating. I mean, Filter forge has come out with the new 4 but I can't even get 3 to work. |
| Posted: April 11, 2014 6:09 pm | ||
