MKBreuer
MKBreuer
Filters: 47
Hy!
I can`t submit any new Filter. Only Update the older one.
It fail all time and tell me i have to do it later.
Is this because FF will be new restructuring or do i something wrong.smile:?:
Just simple, but not simpler. (A.E)
MKBreuer
MKBreuer
Filters: 47
I submit a little one Filter in the morning and by the next,
a bigger one, it comes the failed message.
After that i reading a bit in the Forum, but I find nothing what can help me.
I controll all Components, no HDRI-Problems.... smile:?:
So here is my
...is there anybody out there???
mw_Studio Light_Tri.ffxml
MKBreuer
MKBreuer
Filters: 47
An other Question:
Give it a limit for the Setting? And how many?
Can anyone help, please? smile:|
I've asked the devs to take a look at your filter.
marwyn, the devs say your ffxml contains an impossible combination of components. Have you by chanced edited the ffxml file manually?
MKBreuer
MKBreuer
Filters: 47
Hy, GMM!
No, i haven´t.
But,
> i sometimes copy & paste components from a other filter who i made
> with this filter was the same problem
> i remember that i had a render-bug with it, i do something wrong to submit this problem
> all this comes together with a pc-bluescreen-crash
for the crash,
> i install for everything new updates
> i made a backup from the Filter-Libary and install Filter Forge new
> copy & past only a handful of Filter back
> and change the CPU-Render to Single Core for a lower charge
> (64bit AMD Duo Core 3,0 / Nividia GTX 560 )
now
> FF runs fine but i have this Filter-Problem only when i try to submit it
I think i will rebuild this Filter as a new one.
Yes, marwyn, it's a good idea to rebuild this filter from scratch and see if the problem persists.
MKBreuer
MKBreuer
Filters: 47
Ok, thanks for your help! When i found something, i will let you now.....
smile:!: Crash Info -> Bluescreen smile:!: for everyone who was interested in:
my Set:
> Win7 / AMD Athlon 64 X2 6400+ / Nividia GTX 560 / 6GB RAM
the Crash
> my Bluescreen-Crash was a --> dxgmms1.sys <--
> i find out that this is a --> DirectX <-- Problem
> to check it --> dxdiag <-- into command entry field
> and i install DirectX 11 new
> and new Updates for everything
other thing: it can be a RAM-Malfunction
Solution that i found:
> checking Ram with Memtest86+
> for a stable Run you can set the Voltage for the RAM higher (Bios)
> i have much too little know to say what there are the best Se ttings
> i hope it kills all the problems for the future or i must buy something new smile:|
for more Info about the own Pc-Setup:
> CPU-Z (Mainboard...) / GPU-Z ( Graphic Card)
for contolling GPU Clock speed, GPU Voltage, Memory Clock speed and Fan speed
> EVGA Precision x 3.0.4 / (evga.com)
> (Nividia Cards. I think for other Cards there are something similar)
MKBreuer
MKBreuer
Filters: 47
smile:!: Complemental smile:!:
Speed up RAM --> Optimize your Prefender <--
> Win 7 loads frequently used programs during startup into memory
> The downside: large amount of data collection
> Windows-7-Prefetch-Manager-2012
> more Info about: Windows 7 & SSD: defragmentation, SuperFetch, prefetch
enhance virtual Memory Pagefile
> Start Button > Control Panel > System and Security > System > Advanced system settings
> Advanced Tab > Performance Group > Settings > Advanced Tab
> Virtual Memory Group > Change
> check off Automtically > check your System Drive C: > check Custome size
> The Initial size must be the Recommended Number under the Total paging Group
> The Maximum size should be twice of that Number
> click Set > ok > ok and Restart
> helpvideoguru
helper
> System-Monitor-Mini-Gadget
> 3DMark 11 / Free Basic Edition
> no errors or malfunction > simple: you need more RAM like myself smile;)
MKBreuer
MKBreuer
Filters: 47
smile:?: smile:cry: smile:?: smile:cry: smile:?:
I rebuild the Filter 1 to 1 from scatch, but I can`t submit it to the Libary!!!!!
To many Settings??? I had now Crashes with it.
The Filter by itself works fine.
If you could watch over it again, here is the new one:
MKBreuer
MKBreuer
Filters: 47
mx_Tri Eye.ffxml
MKBreuer
MKBreuer
Filters: 47
Hy GMM!
I think i found the Submit Failed Combination in my Filter smile:!:
I send one with lower Setting and without this Comb as a Test with success!
So can you check this?:
MKBreuer
MKBreuer
Filters: 47
Forget it!
I can´t submit without combination.... smile:?:
MKBreuer
MKBreuer
Filters: 47
Hy, GMM!
Here is a other one and its similar to the mw_Studio Light_Tri-Filter.
I have tested a lot of combination but i also can't submit it.
I know jet that it has nothing to do with the number of Settings,
because I've already sent some other filter.
The only difference I noticed is, that i use there Math-Combos.
But one further transfer test was not successful.
If you find something let me now! smile:|
mw_Studio Light_Led.ffxml
marwyn, thank you for your reports, we've figured it out. Your issue is caused by an error with Free Ellipse versioning (if you try to create your filter in 4.0 beta you'll see the component has been changed). Please try to replace all Free Ellipses with their obsolete counterparts called Free Ellipse 2.004.
MKBreuer
MKBreuer
Filters: 47
smile:banana: smile:D smile:ff: smile:D smile:beer: smile:D ....> Great! i will change it. TX!
I guess the issue has been fixed in 3.012 - you should be able to use Free Ellipse again.
MKBreuer
MKBreuer
Filters: 47
Great!
I have updated the mw_Studio Light_Tri with 2.004 Version,
but in my mw_Studio Light_Led - Filter must be a similar issue! It doesn`t run....
MKBreuer
MKBreuer
Filters: 47
a new submit failed smile:!:
what i have done:
i´d changed some for around the Edge-Finder, for a better technical Look.
and as i what update it,....failed! -> but i think that not the problem.
MKBreuer
MKBreuer
Filters: 47
The Filter:
mx_Tri Eye.ffxml
marwyn, thanks again for your report - it uncovered one more issue.
Please take a look at the IntSlider named "Tech > Profile". It has a subtle note that the component value is limited to 5. You've encountered a client/server mismatch: the client treats this as a soft warning and allows submission, but when the server checks the submitted file it considers this a Filter Problem and rejects the filter.
You can wait until we fix this on the server side or you can modify all IntSliders so that they don't display the "Value is limited" note.
MKBreuer
MKBreuer
Filters: 47
Ok, i think i will wait... the filter is almost there...
For the other Filter it will probably be the same?!...thx
