Minnie
Margaret B
Hi, I don't know if there is anyone who can help. I recently purchased FF 3 and also the backup library. I have vista installed on my pc and the instructions I received was to copy the downloaded filter library into appdata/roaming. I have done this but this file does not appear to be able synchronize with Filter Forge. I am assuming I have to do something else to get it to work and I have tried all sorts of combinations,without success. There is also showing in the list of contents FF 3. The file I copied here is a zip file. I have tried unzipping it but it makes difference. I've tried contacting FF but haven't had a reply I suppose it's down to the Christmas period. smile:?:
profundities
Hi Minnie,
I've just made the same purchase. The directions sent in the email that contains the zip file is missing the first step. Here is what I did that worked for me:
-I unzipped the file using 7-zip
-Then I copied the Filter Forge 3 file (look within the file you unzipped for it) to (just as the email directed for Vista users):
C:\Users\Your_User_Name\AppData\Roaming
- It is important to note that I already had a Filter Forge file there but that did not cause a problem at all
- Next I did click 'Yes to All' when I was asked for confirmation to many different warning windows
Once I did all of this all of the filters loaded beautifully. Many thanks to whomever took the time to send them! smile:)
I hope this helps you Minnie smile:)
occasional moments of profundity...
16 unregistered users.
