Grauer Star
Hi,
i have updated from PSE10 to 11. But Filter Forge 3.011 is not working with PSE11. I've copied the Plugin Files manually from the PSE10 Folders to the PSE11 Folders. After that PSE11 shows Filter Forge in the Plugin Menue but if i click on it something crashes.
Then I've tried to reinstall Filter Forge, but it is not recognizing PSE11.
Any Ideas what I could do else?
Greetings Heiko
MKBreuer
MKBreuer
Filters: 47
Hy!
This is my Installation-Path and it works fine.
C:\Program Files (x86)\Adobe\Photoshop Elements 11\Plug-Ins\Filters\Filter Forge 3
Just simple, but not simpler. (A.E)
bagheertje
Hello
I have the same problem as Grauer Star, today I downloaded the latest update so FF would work with my PSE11.
I have the same installatio-path as you Marwyn, but it just doesn't work; the program crashes and I have to CTRL+ALT+DEL because I can't do anything ... smile:(
