Hello,
I mostly and mainly use Filter Forge in standalone mode because as FF do not support layers I think that it is the same to open the image or photo source from Photoshop (or similar compatible host) or load it in FF. Please, I want to ask you all that have used already both ways the following questions: 1 - What are the differences between using FF as standalone and as plugin? 2 - What benefits and advantages (or disavandtages) can you have using FF as a plugin? 3 - Why would you recommend to use standalone or plugin version? Why choose one or another ? 4 - And I think that more important how FF works as a plugin vs standalone? I mean if it exactly the same code and program or it works probably in a different way. Is it the plugin ONLY a bridge for connecting FF to the host, and nothing else is shared or FF works in a possible different way as a plugin versus standalone. 5 - If you get an error or bug in the standalone version (or plugin) will you get exactly the same bug using the standalone? I mean that if I use one or another could it be fixed in some way. (of course that this would depend on what kind of error you are getting and kind of bug it would be) 6 - If there is a bug in FF standalone, the bug will kepp the same in the plugin, or it depends of what kind of bug is it? I mean that if I am getting an error and this is because a bug in the standalone version, if I use the plugin version could it be possible that this bug could be solved and do not appear or the plugin is only a bridge for FF 7 - I know that both version share the same engine and grapical interface, but are there any differences in working with standalone or the plugin? I mean if FF works in exactly the same way and is completely independent of the host you are using and nothing is shared and all the work is made only by FF and does not use any part of the host program. Or it depends of what host you are using? 8 - How important is the host of the FF Plugin ? Is there any advantages for using Photoshop versus any other compatible host ? Would you get the same perfomance and speed? DIFFERENCES I FIND FROM USING STANDALONE VS PLUGIN I am sorry, that I do not find many differences between both, but I do not see the point why is better to use a host to use FF versus using it in standalone mode. The only thing I see is that in Photoshop (or similar host) you can keep working on your image and manipulate and modify it until you need to apply a FF filter, and the you after this you can continue working on the image and make more changes, and then can apply a second filter and keep again working on the image. As far as I know you can´t use FF with Photoshop actions that would be the real point to use the plugin. Thanks very much for your opinions, comments and experience about this that you may have and want to share in this thread here and help to know more about how FF works. |
| Posted: December 7, 2011 8:44 pm | ||||||||||||||
| Gene S Morgan |
Thanks for asking these questions SpaceRay. I recently was shocked to find out that my most recently submitted "Homemade Paper" filter does not seem to work properly when hosted in Photoshop. I had tested it a lot before putting it in the library and it seemed to work, but now it just won't work right as a plug-in. Hope folks can answer your quwstions. It would sure help me as well .... Gene
| Posted: December 7, 2011 9:36 pm | ||||||||||||||
Glad that you asked these questions.
With my experience of both version, I prefer to use the standalone. When used as a plugin, it takes me longer to make it appear compared to the opening of the standalone which opens instantly. I do not have Photoshop but a similar compatible host which takes time to open because of the number of plugins in it, and time again to open the FF plugin. The standalone does not cause me any problems. visit https://gisoft.ca |
| Posted: December 7, 2011 11:03 pm | ||||||||||||||
From my experience....FF seems to be more stable, runs smoother, and renders faster as a stand alone app....which I attribute to the host app and FF sharing resources....and FF being a 32-bit app running on my 64-bit host programs... The higher risk of error running FF as a plugin is more than enough for me not to use it as a plugin...
| Posted: December 8, 2011 1:33 am | ||||||||||||||
| Lucie |
I've always used FF as a plugin because I always work in photoshop and really don't like switching from one app to another. Because I've never used it as a standalone I can't compare really, but I've never had any problem using it as a plugin and am happy with how it works and the result I get with it. A couple of reasons why I also like using it in photoshop is I can use the "fade" tool in photoshop when I apply a filter to an image and I can also apply filters to different layers and play with the blending modes to get various effects and those are things that I use very often. Unless I'm mistaken, I don't believe I can do this in the standalone, or not as easily anyway...
Lucie |
| Posted: December 8, 2011 8:15 am | ||||||||||||||
Tom Gore
Posts: 23 |
I only use Filter Forge as a Photoshop plugin.
Usually I copy my image to a new layer, modify it in Filter Forge and then blend it with the background image. Using Filter Forge as a stand alone would involve opening the image, running Filter Forge, saving the modified image, then opening it in Photoshop, copying it, pasting it into the original image and blending the copy layer with the background. In a word, much more of a fiddle, as I learned when the plug-in didn't work with the OS X Lion upgrade for a while. |
| Posted: December 8, 2011 7:20 pm | ||||||||||||||
Thanks very much for all your comments and experiences, it is very interesting to see different point of view, and ways to use FF.
I would like also if it would be possible to have also an opinion from the the Filter Forge team, and what they think about this. Of course is also welcome any other comments, opinion and experiences of any other FF user. Please, continue sharing your experiences and what you think about this topic here |
| Posted: December 13, 2011 3:34 am | ||||||||||||||
Posts: 3498 |
I cannot speak for the entire team but I doubt that Vladimir or Kochubey who are the most active internal FF users will get to this thread soon.
I'm not an active or expert user of Photoshop and compatible apps. For me the most obvious advantage of the plugin is the ease of applying an effect to a selection.
Again, I do not use host applications much so my opinion may be biased. Naturally, I use the standalone version and I tend to agree with Ghislaine above.
Exactly.
Of course it depends on the issue! For example, the most popular bur report is about the pipe is being closed issue which occurs when the host application terminates unexpectedly. This issue cannot possibly appear with the standalone FF version.
To my knowledge, all hosts that we support officially should work with Filter Forge exactly the same way. |
| Posted: December 13, 2011 8:44 am | ||||||||||||||
WOW!! GMM thanks very much for all your comments and answers !!! Very appreciated.
I HAVE NOT USED ANY OTHER HOST APPLICATION THAN PHOTOSHOP I have to say that I have NOT tested FF with any other host compatible other than Photoshop and this have been a very short experience, as I said nearly most of the time I only use it as standalone and then after I could load it into Photoshop.
Good to know that then FF does not depend or use any of the host features and only acts with the host loading the images (and any other data needed) and sending them back with the filter applied.
Yes, if FF does not use any feature of the host and ONLY acts as a bridge as said above, it really does not matter the host and should work in exactly the same way, perhaps the question could change in this case What features that Photoshop offers are not found on other compatibles hosts? I mean things that you can do in Photoshop and interact with FF, for example the selection
Can you apply a FF filter to a selection made on the image from photoshop ??
Oh I am very sorry that I did not know that and have never tried to do this, thought that FF only used FULL images and not selections, and is true that as you say, this is a really great advantage, I will have to test it. I suposse that there must be MORE advantages using Photoshop or any other host than this one. I will have to dust off the FF Photoshop plugin |
| Posted: December 13, 2011 11:43 am | ||||||||||||||
I am glad too that you like them and are useful
YES, is the same to me, I prefer to use it as a standalone because it opens instantly and can begin to work very quick, and using it as a plugin, must start the host and then the FF plugin. Although, this is a problem of Loading time, I have recently been lucky and fortunate that after 6 years waiting I have changed my computer and have put a SSD drive SATA 3 and this has changed MUCH, and if before I have been waiting a lot of time for application to load, specially big ones like Photoshop, now the load time is MUCH less than before and Photoshop opens in a few seconds.
Yes I agree with you, I think the same as you and have seeing and experienced the same, and that is why I have been using it mostly as a standalone VS plugin. FF is not a 64 bit application and using a 64 bit host have a higher risk of errors.
Very interesting to find someone that has NEVER used FF as a standalone I am glad that you have never had any problems as a plugin, I have had some problems and that is why I have prefered to use it as a standalone.
YES, I agree with you, as I have just wrote above, I agree that if you need further modification and the FF result is going to be used as part of an ongoing project and you mwant to include it in others images or use the blend modes, is better to use FF as a plugin. Is true that is much better and faster way than using as standalone. |
| Posted: December 13, 2011 12:32 pm | ||||||||||||||
As now the only good way to use Filter Forge is as a Plugin and not as a standalone to be able to avoid the bad and unwanted "Bad Allocation" bug (at least in Windows) I want to bring this thread up again for anyone that want to know the difference.
Anyone that knows or want to add more advantages, comments or anything that could be useful to this thread is free to do it and welcomed. |
| Posted: July 9, 2012 1:29 pm | ||||||||||||||
All I can say is that with large enough images I managed to squeeze a bad allocation error from FF while in plugin mode
| Posted: July 9, 2012 3:09 pm | ||||||||||||||
What do you call "large enough images" ? Is true that is possible to get a bad allocation error EVEN when using FF as a plugin but is much more difficult that this happens, at least in my tests I made 32 renders with different filters and got only 2 bad allocation errors, all with 10.000 x 10.000 pixels |
| Posted: July 9, 2012 11:04 pm | ||||||||||||||
Yep, I agree, it's much more rare to see a bad allocation error in plugin mode.
The image I used was a mere 4000x3000 image, but I think it's a combination of image size, filter complexity, filter settings (which preset is used), and other unknown variables, like having all the filters from the online library (9000) and most filters from the forums (1000+)... I did manage to get the full render though, more than once, so I can't say for sure what made FF hickup that time. |
| Posted: July 10, 2012 2:13 am | ||||||||||||||
I have recently found one difference that is good using as Photoshop plugin, it may be silly, but I have never before tried to use a selection from a layer to fill it with a FF effect from a filter, although this does not work in all the filters and depend much if the filter can recognize alpha channel and transparency, I think this is something good to use FF as a photoshop plugin that I have just discovered.
Making this same thing in the standalone would slightly more difficult as you would need to save the selection of the layer image on a file and then load it into FF and then save the result, and in photoshop directly you do not need to save anything as is done directly. I still think that for the things I do and considering that FF is a powerful and resources hungry software, would be better if possible to use it as standalone instead of plugin, so it can have all the computer power for itself instead of having to share it with another powerful and resource hungry software like Photoshop. |
| Posted: June 27, 2013 5:01 am | ||||||||||||||
I have found 2 more important differences between using Filter Forge (FF) as standalone versus plugin
FF CONVERTS TO 72 PPI WHEN SAVING THE RESULT FROM FF SOFTWARE StevieJ has told in this thread FF Killing Resolution that all the images that are saved through the standalone version of FF with the menu File-->Save or Save as will be converted from whatever resolution it has the original (for example 300 ppi) to 72 ppi. The good thing is that FF does not resample the image so it will keep the same size resolution and so it will not change the quality or the pixels amount of the result and so then you can easily change it back to the original resolution (back to 300 ppi) with Photoshop or any similar software that can do this, and there also free software that can do this too, BUT the important thing is that when changing it back to the original you must NOT use and deactivate the resampling A good news is that this does NOT happen if you use FF as plugin with a host software, and instead of saving the image with FF you just and only APPLY the filter from FF to the original source image, and it will keep the same 300 ppi (or whatever it may have) that the original image had before applying the FF filter. Although even using the FF plugin you can´t save directly from the plugin using the File-->Save because it will also convert it to 72ppi in the same way as it happens with the standalone version, so as I said, using the plugin version is suggested and recommended to only use the APPLY filter. FF WILL CONVERT ANY IMAGE LOADED TO sRGB COLOR SPACE WHEN SAVING THE RESULT FROM FF SOFTWARE This is the main reason I will not be using the standalone version anymore. Making tests with the above, I have also discovered that FF will always save the result in the standalone version with the sRGB color space EVEN if the original source did not have this color space, so it will convert it without asking for your permit to do it and FF will not tell you that it has converted your image to sRGB. So this is a very important (at least for me) thing to know. The good news is that this does NOT happen if you use FF as plugin with a host software, and instead of saving the image with FF you just and only APPLY the filter from FF to the original source image, and it will keep the same color space that the original image had before applying the FF filter. Although even using the FF plugin you can´t save directly from the plugin using the File-->Save because it will also convertto the sRGB in the same way as it happens with the standalone version, so as I said, using the plugin version is suggested and recommended to only use the APPLY filter. See also Why FF converts all the images to sRGB color space WITHOUT asking? |
| Posted: July 30, 2013 4:57 pm | ||||||||||||||
I wonder now IF the differences are the same IF you are using either Windows or Mac as they have different OS and different way to make the software work, so maybe there could be some possible other differences that are only for Windows or only for Mac
Maybe on Mac it could be faster to use plugin (or stand alone) than in Windows, or the other way Also it will depend maybe if you are using FF 3.0 or FF 4.0 (or if you are still using FF 2.0) And also could depend on what version of OS you are using |
| Posted: October 4, 2014 12:14 am | ||||||||||||||
Different compiler. Simple as that. [edit] and probably a bunch of other technical things.
| Posted: October 4, 2014 2:56 am | ||||||||||||||
i think that depending on the purpose and filter you may be using, it may have more or less advantages to use the standalone versus the plugin.
i am using Photoshop CC for 10€ each month (photography plan) that I think is well worth and great price for having it BUT. Be aware that photoshop seems to NOT BE THE ONLY HOST, as in Windows OS,there are others plugin hosts, there is a list somewhere in hte forum |
| Posted: August 28, 2015 11:33 pm | ||||||||||||||
Does anyone else have found any other difference, advantage or disadvantage for using FF as standalone or plugin ?
It seems that if you want to keep the original source image settings (for example dpi and color space) you need to use it only as a plugin There may be other things that maybe we do not know yet |
| Posted: January 21, 2016 6:11 pm | ||||||||||||||
Haras Arch
Posts: 226 |
I haven't tried to use FF as a plugin program.
As a standalone program, there are some filters that don't work because I can't make a selection I also had an issue with saving tifs and emailing them to someone -- the images, although the size looked fine when they left my computer, were evidently so big that his computer couldn't handle them (or something else went wrong; anyway, his email crashed when he tried to view the images). I had to compress the images using PhotoFiltre Studio and resend them before he could view them. Also, the thing about tifs automatically saving at 72 DPI (I have another thread going about that right now). |
| Posted: January 21, 2016 6:22 pm | ||||||||||||||
McGyver
I personally prefer to use FF as standalone, as it seems slightly slower in photoshop... That could be because I have older versions of Photoshop, CS 2 and CS 3. Also there were a few filters that did give as great results in PS as in standalone... I forget which, but if I recall correctly they were usually ones that needed a selection. Too bad FF can't work with GIMP, because once Adobe turned to subscription only, they lost me as a customer.
| Posted: January 21, 2016 10:40 pm | ||||||||||||||
Posts: 3498 |
You can! Just go to the File > Open Selection menu. |
| Posted: January 22, 2016 5:05 am | ||||||||||||||
Haras Arch
Posts: 226 |
It tells me to chose a picture when I say "open selection" then says "The selection must have the same dimensions as the main image" and gives the beep sound that means that what I've tried to do has failed. If I pick the same image as the open image AND the open selection, then I get some sort of subtle layering effect of the two images. |
| Posted: January 23, 2016 3:21 pm | ||||||||||||||
https://www.filterforge.com/more/help/...tion3.html Help file states:
Basically a selection is really just like a map that indicates what's been selected and what's not been selected. The map is grayscale, which determines to the degree of a specific selection. |
| Posted: January 23, 2016 10:05 pm | ||||||||||||||
Haras Arch
Posts: 226 |
OK, probably a dumb question, but I thought that when I picked selection I would be asked what portion of the picture I wanted to apply the filter to, or something like that. How does opening a selection actually differ from opening an image?
| Posted: January 24, 2016 2:29 am | ||||||||||||||
Posts: 3498 |
No, you need to prepare the selection file before you open it Filter Forge. Paint the selected area white and the deselected area black, as stated in the help file. |
| Posted: January 25, 2016 6:36 am | ||||||||||||||
33,772 Registered Users
15,367 Topics
+57 new in year!
19 unregistered users.
