Hello,
I have been searching on the Filter Forge Forum, Tutorials, Wiki and help guide but have not found any reference on how to use in the best and correct way Filter Forge with actions in Photoshop so that some things could be done automatically and repeated. For example to make a action to batch render in FF and apply the same filter and same settings to 40 photos Another example is to apply 10 different filters to the same photo, and get 10 different photo results each one with only ONE of the filters applied. I have also been searching with google but have not found nothing either. The only probably thing is to use the command line renderer (CLR) as seen in this thread here and here BUT I do not want to use this CLR, I want to be able to use the photosop Actions. Please, is there any help for creating Actions for using FF in Photoshop ? Thanks very much |
| Posted: November 18, 2011 1:38 am | ||||||
i would think your best bet is to check the photoshop manual(s) and helps and help sites. someone else here mentioned that you could do it, so maybe they'll chime in, too. but there shld be plenty of sites that give instructions on using actions.
| Posted: November 19, 2011 8:54 am | ||||||
Thanks for the suggestion Kraellin, I have already seen a photoshop manual, but it seems that I am not able to know to how to do it, and what I have tried it does not work, so that is why I am asking this here, as I do not know what happens.
Perhaps is because what Crapadilla has wrote in this other thread
So it seems that is not possible to make and action because PS does not "talk" to FF and for recording to be able, must happen inside FF, and this is not possible in the FF actual version. |
| Posted: December 3, 2011 3:31 am | ||||||
27 unregistered users.
