I am sorry that I do not understand the instructions given to use the Command-Line Renderer
The main problem I have is that I do not know how to prepare and make the first XML file needed. Do I need to make a learning of XML language before using this ? I have already read all the whole text twice of that page given as intrustions, but regretably do not understand how to use the XML tags to built the XML file. I have also serched in the forums for more information and did not find anything, the only information is for making animations but not still images 1 - How do you tell which filter and which preset do you want ? 2 - How do you tell where is the source of the image that is going to be applied? 3 - Is it possible to apply the same filter and preset to a whole folder of images ? 4 - Is it possible to apply 2 or more different filters with the same presets to the same image ? 5 - Is it possible to apply the same filter but with 4 different presets, so you would have 4 different images (using the same source image) with this 4 presets applied? 6 - Can the resolution of the result be changed or must always be the same as the original source image? 7 - Would be possible to have some XML´s available in the forums that they have already made this features in the same way as there are snippets ? Thanks very much for your help
| Posted: August 23, 2012 3:22 am | ||||||||
Posts: 3507 |
There is not that much to learn beyond editing of plaintext files, though reading a Wiki article on XML won't hurt. Here is a more streamlined version of the task file, with all optional sections omitted. Please open it in Notepad, place its window alongside with your browser, and reread the first part of the XML File Contents section (about the 5 mandatory tags), while looking at them in the XML sample. This should give you the basic idea what the XML file is constructed of; if you have any questions after that feel free to ask. [ BatchSample.xml ] |
| Posted: August 23, 2012 5:03 am | ||||||||
Well, is not that I am afraid or worried to learn XML, because I can do it, I was asking if it was needed. Thanks for the link anyway.
Thanks for the Batch sample file Now is more clear for me and understand it better. Will have to see how it works and try it and then I could make some questions |
| Posted: August 23, 2012 5:47 pm | ||||||||
I have been trying to make this but it seems taht I need to learn more about XML and making scripts or using the Command Line renderer as until now I have not been able to use this, but I will try further and see what I can do.
Please, if anyone knows more hint, tips or suggestions about this tah could help would be very good, useful and appreciated. |
| Posted: October 10, 2012 3:27 am | ||||||||
33,846 Registered Users
+12 new in 30 days!
+257 new in year!
16 unregistered users.
