Login - Create Account
Bookmark and Share
Photoshop 64-bt Plugin Failed to Load
Digital-Flare
When launching the plugin within Photoshop 64-bit CS5 the UI window displays, the main toolbar is accessible, however, the plugin fails to load and filters or adjustment controls. The Photoshop file contained only 1 layer (no, FXs, not a smart object, and no vector masks)
Digital-Flare
Additional bug:
After closing and relaunching the plugin within Photoshop 64-bit CS5 a window displays stating "Plugin Already Running - Click Here to Switch". Clicking causing Photoshop to crash. Here's the error code:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Photoshop.exe
Application Version: 12.0.3.0
Application Timestamp: 4d035d7d
Fault Module Name: Filter Forge 3 x64.8bf
Fault Module Version: 3.1.20499.15522
Fault Module Timestamp: 4db96b2c
Exception Code: c0000005
Exception Offset: 00000000000b4626
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 7ed4
Additional Information 2: 7ed4a7a9ad932aebff72a322d8d670b2
Additional Information 3: 5fea
Additional Information 4: 5fea06065eafa3d75e37c0e8c2b02572
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linki...cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
You can click this panel in 4 cases. Which of them is yours? Does the issue reoccur in other cases?
1. You start FF from within Photoshop and quickly click the panel while FF UI hasn't been initialized yet.
2. You apply a filter in FF and click the panel while rendering is active.
3. You close FF and quickly click the panel while FF UI hasn't closed yet.
4. You work in FF then Alt+Tab to Photoshop.
Also, please navigate to Program Files\Adobe\Adobe Photoshop CS5\Plug-Ins\Filters\Filter Forge 3\Filter Forge.config, open this file in Notepad and change the IndependentUI value to true.
Ellie
I can't even get the filter to show in my list of Filters in Photoshop CS3.
Or does it not work in CS3? Because I didn't see anything about system requirements.
If it doesn't work in CS3, then I just wasted money on the upgrade.
It does work in CS3. In your previous messages you mentioned CS5, so which version are you talking about?
ANDREW SMITH
I am trying to load FF but everytime I try to load the filters into PS CS5 I get this message and it wont work, please advise.
; exit;
Folder permissions changed successfuly.
Searching for Adobe Photoshop CS2...
Adobe Photoshop CS2 is not found.
Searching for Adobe Photoshop CS3...
Adobe Photoshop CS3 is not found.
Searching for Adobe Photoshop CS4...
Adobe Photoshop CS4 is not found.
Searching for Adobe Photoshop CS5...
Adobe Photoshop CS5 found at /Applications/Adobe Photoshop CS5/.
ln: /Applications/Adobe Photoshop CS5/Plug-Ins/Filters/FilterForge.pluginv2/: Permission denied
Failed to install Filter Forge plugin for Adobe Photoshop CS5.
Searching for Adobe Photoshop CS5.1...
Adobe Photoshop CS5.1 is not found.
logout
[Process completed]
Andrew, what MacOS version do you use?
What Filter Forge version are you trying to install?
15,400 Registered Users
+10 new last day!
+16 new last day!
10,106 Topics
+6 new in 7 days!
15 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
