Totte
Übernerd
Filters: 107
(a) The Installer creates a directory in /Applications with very wrong owner, see image.
Translated: owner is set to _unknown and everyone no access.
needed this to be able to run it:
sudo chown -R totte /Applications/Filter\ Forge\ 3
Also, I love the life saver substitutes, but is it (or will it) be possible to set which image to use as the preset image for each preset? I have a few filters that would look zillion times better on the sample preset images on the web if the presets were rendered using something with Alpha channel.
totte, yes, each preset can have its own imported images. i tested that last night and it works great! you could have 20 presets and each of them could link to different images. very slick! you can also use the new resident images and vary those any way you wish, preset to preset. it's very versatile! the only caveat is that you wont be able to submit filters that use imported images into the library. you'll have to reset all of those type images to the resident images... i think. there may be one other option there, like setting to no image or something, but the point is that you wont be able to submit your filters if they use external, imported images. you'll have to change them before submitting.
tigerAspect
Filters: 9
You can also just hit the lock button in the lower right of the info screen, type in your password, then click the plus on the lower left, add yourself from the user list, then set your access to "Read & Write".
Totte
Übernerd
Filters: 107
@Kraellin: great, will try that;-)
@tiger:With the terminal you know it will work, sometimes Finder fails setting permissions down a hierarchy, don't know why but it does.
Totte
Übernerd
Filters: 107
@Kraellin: I just can't figure how, I've really tried smile;-)
How can I get that ladybug as the preset picture?
We'll sort this out in the next beta.
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
23 unregistered users.
