After performing some shaman rituals we've devised a workaround that may allow you to run Filter Forge under CS5 or Photoshop Elements or another unsupported host app in Mac OS X:
- make sure that Filter Forge or your host app is not running;
- copy the entire 'Filter Forge 2' folder from Applications to Applications/Photoshop/Plugins/Filters or to the Plugins/Filters folder of your host;
- delete the filterforge2-ppc.plugin file if you've got an Intel-based Mac (if you have a PPC Mac, skip this step).
- run your host. The host must be a 32-bit application. Filter Forge should show up in the Filters menu.
For Filter Forge 1.0 installations, the procedure is the same except the 'Filter Forge' folder name and the filterforge-ppc.plugin file name.
All your filters, settings etc will be equally available in the plugin mode as well as in the standalone mode.
Please let us know if this magic works or doesn't work for you! smile:-)
finnianm
Filters: 11
Unfortunately, whenever i start FF2 from the CS5 filter menu i get an unrecoverable error D:
I sent a report.
Please make sure you have deleted the filterforge2-ppc.plugin file.
finnianm
Filters: 11
I did, from both of the app folders. Here is the bug report.
Operating system: Mac OS 10.5.8
Physical memory: 3072 MB
Number of processors: 2, available: 2
Processor info: Intel® Core™2 Duo CPU T8300 @ 2.40GHz, ~2386 MHz
Filter Forge universal 2.007.17070.57746 Release-10.5, June 07, 2010 08:57 [Fri Jun 11 11:55:15 2010 -0500]
Bundle path: /Applications/Adobe Photoshop CS5/Plug-ins/Filter Forge 2/Filter Forge.app
Critical exception occured at thread 0xb0438000 'RenderingMgr 0x18caa00/0':
<XFW::Exception> Application encountered an unrecoverable critical error and will be terminated.
Critical exception call location:
__gxx_personality_v0 + 1108 at 0x922c010c in libstdc++.6.dylib
std::terminate() + 29 at 0x922c014b in libstdc++.6.dylib
__cxa_rethrow + 79 at 0x922c02b1 in libstdc++.6.dylib
<unknown function> + 0 at 0x005b88d8 in Filter Forge
<unknown function> + 0 at 0x005b8a32 in Filter Forge
<unknown function> + 0 at 0x0030ce73 in Filter Forge
<unknown function> + 0 at 0x0031839e in Filter Forge
<unknown function> + 0 at 0x0030d2b0 in Filter Forge
<unknown function> + 0 at 0x00308d11 in Filter Forge
<unknown function> + 0 at 0x0030c78b in Filter Forge
<unknown function> + 0 at 0x0030d5d2 in Filter Forge
<unknown function> + 0 at 0x00308d85 in Filter Forge
<unknown function> + 0 at 0x005b5a18 in Filter Forge
<unknown function> + 0 at 0x005c2444 in Filter Forge
<unknown function> + 0 at 0x0055e9fe in Filter Forge
<unknown function> + 0 at 0x005914b1 in Filter Forge
Possible original exception location:
<unknown function> + 0 at 0x0082a737 in Filter Forge
<unknown function> + 0 at 0x005796ce in Filter Forge
<unknown function> + 0 at 0x0056fd82 in Filter Forge
<unknown function> + 0 at 0x0057083f in Filter Forge
<unknown function> + 0 at 0x00570c9c in Filter Forge
<unknown function> + 0 at 0x00581a61 in Filter Forge
<unknown function> + 0 at 0x0082874a in Filter Forge
<unknown function> + 0 at 0x00581c7e in Filter Forge
<unknown function> + 0 at 0x00808de1 in Filter Forge
<unknown function> + 0 at 0x0080946d in Filter Forge
<unknown function> + 0 at 0x00832d3c in Filter Forge
_pthread_start + 321 at 0x91aa9155 in libSystem.B.dylib
thread_start + 34 at 0x91aa9012 in libSystem.B.dylib
steveshead
Steve Shead
The workaround worked for me - I'm running Photoshop CS5 in 32bit mode since Alienskin plugins aren't supported in 64bit mode yet.
_gh_
none
yes this worked Mac os x 10.6.4 Photoshop CS5.
Mac os boot in 64 bit mode
PS CS5 in 32 bit mode only
none
droderick
I'm in Photoshop CS5, Mac OS 10.5.8 and feeling kinda dense. This should show up under filters, right? It's not there at all as near as I can tell...
(it's working fine as a stand alone)
droderick, please make sure you're running a 32-bit Photoshop.
Costello
I just purchased Filter Forge and am having the same problem as droderick. I have installed FF in my CS5/plugins/filters folder exactly as suggested in the workaround. The program works as a standalone and I've re-installed my old copy of CS4 (it works fine there), but Filter Forge doesn't show up at all in my CS5 filters menu. I tried changing to 32-bit under "Mode" but that doesn't help. (If that's the wrong place to set the preference, I'd appreciate any pointers.) What am I missing here? Filter Forge appears to be a powerful and interesting plug-in but I can't get out of the starting gate in CS5.
Modified: Okay, was able to get it to work. No reply necessary.
droderick
I was embarrassed to ask where to find the 32-bit selection was (I couldn't find it in preferences) but finally checked out the readme that came with the app and found it by selecting "Get Info" on the application itself.
And now FIlter Forge works! So, thanks!
LakeEffects
LakeEffects
Yes, it works! Thank you. I will now pick up all the hair I had torn out and thrown about the room. smile:)
DebraS
jwbworks
Hello all.
Adobe just sent out an update for PS (for handling cs4 screens was the description). When I restarted PS FF and FF2 no longer showed up under filters. I just did the work around again, and restarted PS, but still FF and FF2 do not show under the filters menu. Is anyone else having this problem?? I am working a time sensitive project and need to get back up and running as soon as I can.
Thanks
Jeff
33,849 Registered Users
+7 new in 7 days!
15,392 Topics
+44 new in year!
16 unregistered users.
