Messages 1 - 45 of 404
Gene S Morgan
Filters: 81
I always hoped more people would post their own artwork using FF. I was inspired lately by Chazzy's Blocky filter because I mentiond to him that it would be more useful to me if he added a saturation node. To my surprise he did. This how I recently used it.
I design T-shirt artwork and this is one example of what I do. I'm not any kind of great artist but some crazy folks do buy my stuff sometimes.
The figure was created in Poser and I applied my own Old Book Illustrator filter to it. The background was started with a design I made with my Puzzles, Streaks,and Strings filter followed by Chazzy's Blocky and finished with my Colored Dirt filter as a final.
My T-shirt site is Captured Image Design in case you want to check out more designs.
Gene S Morgan
Filters: 81
Here is the graphic
Chazzy
Chazzy
Filters: 28
Wow! Amazing work!
Gene S Morgan
Filters: 81
Thanks Chazzy .... Hoped I was doing good with your filter .....
Gene S Morgan
Filters: 81
Here is another music related design of mine of a banjo picker. Again I used my Old Book Illustrator on the figure. The background was created by starting with a blank file with a filled background. Then I applied some random contrasting colored lines and splashes. Then I applied my This Way and That Way filter. To produce a rough wall kind of feel I used my Color Texture Emboss filter.
My Website.....Captured Image Design
Gene S Morgan
Filters: 81
I have often used abstract artwork as backgrounds in my graphics. I always liked to use painter's glass distortion to create abstracts. I find FF has so many cool ways to produce abstracts which are easier and require fewer steps. Abstract painting depends on balance between color, light and dark, structure and texture. By using lines and shapes in photoshop in a file with those elements in mind and distorting in some way you can end up with some very cool abstract art. This image was made that way with only a variation of my This Way That Way filter to get these results .....
My Website ....Captured Image Design
Gene S Morgan
Filters: 81
You can get Abstract art by just banging away on the random variations button on any distortion type filter and wait for something good to show up. If you use a filter that only does small area distortion or color effects you can get more control of the final results. Here is an image I did in just a couple of minutes withh the goal of an example rather than great art.
Gene S Morgan
Filters: 81
The lines and colors were painted on the previous image with some thought of color balance. There are a lot of cool filters up here that could mess this image up a bit and make it look more like abstract art. I use mine because that is why I made them. I started with my Exploding Globs(one of my first filters) filter to mix things up a bit. The key is to use a combination of filters to get a unique final look. I used my Image Abstractor Wild/Boxy filter to further change the image. I admit the result is not great art but then again I ain't no Picasso. It should give you an idea of what is possible. I have used this kind of random art in designing backgrounds for some of my work and also making jewelry designs .....
My T-shirt website ....Captured Image Design
Gene S Morgan
Filters: 81
Most of you folks have figured out by now that I'm not a rocket scientist when it comes to creating filters and making art. I have been trying to create computer art since 1979 with my trusty old Radio Shack Color Computer. Back then if you wanted software you had write it yourself, so I learned enough basic programing to create graphic software. I always believed that creating was as much an art form as a technical problem. I see making and using FF filters much the same way. I just sit down and play until something nice happens. That is why I like abstract art and texture backgrounds. Watching the pretty colors and shapes appear on the screen is kinda therapy for me.
I started this abstract with a random graphic created with a basic program I wrote ..
Gene S Morgan
Filters: 81
OK, so I messed up a bit. My finger got away from me wacking on the the variation button in my Rainbow Connection filter and I forgot to hit save. I'm not really sure how it happened, but I came up with a nice color combination. That is what I was trying to do, break things up a bit and add color, but I will probably never be able to get it again. Let that be a lesson to me. Then I ran my Modern Art Abstractor filter to get more texture. I got this .....
Gene S Morgan
Filters: 81
I liked the shapes and textures, but I ran the filter again and got more of a paint brush effect. Is It Art? Who knows, but I like it ....
My T-shirt website ... Captured Image Design
Gene S Morgan
Filters: 81
I have been doing graphics for quite awhile and over time I have tried to develope a kind of style. I never tried to make all my stuff look alike, but I wanted to have certain elements to be present in much of my artwork that might set it apart. I was really glad to start using FF because by creating specialized filters I could streamline my design methods and work much faster.
There are 2 features that I often use in my work. The first is an illustration kind of look. That is smooth simplied color and detail and ink like outlines. I used to use the old Buzz Simplifier filter to smooth the image and a number of different methods to add outlines. To make it easier to accomplish that I have added those type of effects to many of my filters. On those first couple of examples I used the musicians looked like flat watercolor with ink outline. That is part of my style.
This image is a background texture using filters that produce that kind of effect. I started with my Oil On Water and followed it with Rainbow Connection to add some color and ink. Color Grain Paint filter adds more outline and some texture.
Gene S Morgan
Filters: 81
The second element of my style has to do with embossed texture. One of the first graphic programs that could really do a job of embossed backgrounds was Painter. You could do so much with it's paper textures. You could make your art look like it was painted on everything from wood to plaster to anything in between you could emagine. FF added a whole new dimension to adding backgrounds. I found you could emboss both the image and add subtle embossed background texture as well. The texture did not have to be tiled and look very regular. It could vary in size and shape depending on color or lightness or flatness of image color. It Added possibilities to improving my texture style. Several of my filters have variations of this technic.
This is a simple example of embossing texture. I started with my Puzzles, Streaks, and Strings filter. Then I applied my Color Texture Emboss filter. I love the ability to do this without using tons of layers and styles in Photo Shop.
My T-Shirt shop website is ... Captured Image Design
Gene S Morgan
Filters: 81
I'm pretty sure I have mentioned that I'm not a great artist. Most of my drawings and paintings look like cartoons. But, since my style is pretty cartoony it kinda works. I use lots of other tools to create graphics. I have mentioned Poser and Daz Studio. Photography is a big part of my work as well. I have tried 3D design programs, but most of them are so time consuming. Folks may have figured out that I'm an old dude and at my age time consuming is a deal breaker. I read these forums a lot and someone here once mentioned that they spent 20 hours making a filter. Gee, I'm not sure I have 20 hours of life left to spare. If it don't work in an hour or so I move on.(OK, there may be some A D D involved as well) To beat the 3D world time stealer I discovered a great free program called Sculptris. It allows you to create stuff like you were working in clay. It was made for me ...
This image was made and colored in Sculptris. I have a thing about creating faces, especially kinda odd ones. I added the eye detail later in PhotoShop. This is the image before FF magic .....
Gene S Morgan
Filters: 81
One of my first filters to use the technic of simplify and outline was Fake Buzz. It was an attempt to do in FF what I had been doing with other filters for quite some time. It was cool to come up with something that worked and was much faster than all the layer work I had been doing. It is more subtle than some of my other filters. It makes an image look a little less real. I wasn't trying for some kind of fake painting method, just some stylilized reality. That is what I used on this spooky guy .......
My T-shirt web site is ... Captured Image Design
Gene S Morgan
Filters: 81
Another spooky face. I always float my graphic image over the background in a separate layer. That way I can work on each one separatly. I gave the background a shot of my Color Texture Emboss filter to roughen it up a bit. The face is still unfiltered just as it was captured from my Sculptris sculpt. The real advantage of using diferent layers is that you can use PhotoShop layer styles. Sometimes I use stroke or outer glow. This time I added a drop shadow. This makes the top image stand out and separate itself from the background .....
Gene S Morgan
Filters: 81
I ran my Fake Buzz filter on the face and then flattened the layers. I ran my Color Texture Emboss filter on the whole image. It gave the background a more intense emboss and just some subtle areas of texture emboss on the face to give the feeling of it being carved from some imperfect material. I think art should have imperfections. It looks more real world that way ......
My website ......Captured Image Design
All of your designs have a similar style to them. It's cool to see them all together. smile:)
But I would not wear that face on a t-shirt. smile:dead:
Gene S Morgan
Filters: 81
I don't blame you, I wouldn't wear that face on a t-shirt either. But some folks have different taste than we do. I wouldn't wear a t-shirt with my face on it either, but some guys do .... Thanks for the comment .....
Gene S Morgan
Filters: 81
I thinks some folks are getting scared by my spooky faces, so this will be the last one. It is the most spooky of all. You may notice that the color and saturation of the past images is different in the final images. I really believe in hue and saturation control. That is the final node in most of my filters. I like that kind of control. I must admit that I don't often use other people's filters. I got involved in FF to refine my own art by designing my own filters. There are some really great filters up here and now and again I find some of them very useful. I used to add hue and saturation node to all the filters I downloaded. A few months back in this forum Kraellin mentioned that if you change someone elses filter they do not get credit for your use. Now I do not change any filters and do my color changes outside FF in PhotoShop.
This guy was made much the same way as the others. The one comment I have is about the background. Sometimes my textures are too clean and I add some more texture. On this one I ran my Broken Tile Mosaic filter to add some Roughness.
Gene S Morgan
Filters: 81
Just to show I'm not all about weird stuff. Here is a little cutie I designed from Daz3D's Victoria model. A nice subtle use of Old Book Illustrator on the figure and a background created with 2 new filters I just submitted to FF. I first used my Ripples In Time filter and then then my Sand Blast filter. I'm finding the Sand Blast is not as predictable as I originally thought. I may have submitted it a little to soon. But I do like what it did in this image ....
My T-shirt shop is .....Captured Image Design
ronjonnie
Designer / Artist
Filters: 320
Hey Everyone, smile:)
Hi Gene,
Cool work! That background you chose in the image 3rd. from bottom reminds me of one of my filters, it has a similar appearance, I like it. smile;)
Have a Great day! smile:)
Ron
Gene S Morgan
Filters: 81
Ron ..... I checked back and I do think it was your filter .... Sorry I should have given you credit .... As I mentioned I am kinda old with attention issues .... Thanks much for the nice comment ....
Gene S Morgan
Filters: 81
A little bit more about abstract backgrounds .... It is pretty easy to make background texture FF filters. I have made quite a few. Mine are quite simple, but not particularly fancy. The best kind are ones that take an input image and abstract it into something cool. Using different images each time produces a whole new effect with each image. On my second spooky guy image I used a filter made by ronjonnie. It is a filter that goes way beyond anything I have made. It is complex and produces some real nice abstracts. I have been using texture making software of some kind for almost 20 years. (going back to the days of the original KPT filters) I have always searched for something different. This fits the bill ....
This image started with my girl image above. I cropped it square so it could be tiled and ran ronjonnie's Your Fractal Art filter and ended up with a great background with just one pass. Two things I like about this filter is that it is fairly fast (I don't like slow filters ... A lack of patience and short attention span) and the fact that there are some real nice effects hidden in it if you go beyond the presets .....
Gene S Morgan
Filters: 81
Today my 50th filter was posted. I'm not good but I'm persistent. If you aren't making filters yet, try. Just drop in an image input node, the output is already there, and put something in between. (It doesn't matter what .. keep trying) connect up some sliders and save the sucker. Hit the the variations button and watch the magic happen. Most fun you can have with your clothes on.
On this image I used the only filter of mine that the FF folks rejected. I think it was because it was similar to one that already existed. That wasn't because I copied someone elses. Now and again one the old timers here in the forum will rant about how most of the new filters are crap and just copies of older better filters. I do not believe that FF is rocket science. Most of this has all been done before. It is pretty much PhotoShop actions with a GUI. Most of what you can do with it can be done with PhooShop and a few other add-ons. There are some folks up here who have the time and knowledge to produce some complex and really cool filter, and I appreciate their efforts. The rest of us can just have some fun trying everthing until something cool happens.
The image is the last image with my Hammered Metal filter applied .....
My Website ...Captured Image Design
Gene S Morgan
Filters: 81
I like art, so I hang where artist hangout. An artist once asked me if I did art. I said yes on the computer. He frowned at me and said "Oh yeah, photos you turn into paintings with filters" Well sure I've done some of that. But over time I have tried to develope a style that maybe looks like painting and uses some elements of painting but is truely computer art. In my youth I spent many hours in a darkroom (that is how we made photos back in the dark ages for you younger folks) trying to get unusual effects in the magic water. Now I do that with pixels. More fun and dosen't smell so bad.
This is a photo of a Key West sunset where I applied my Pseudo-HDR Illustrator filter. It really blast up the color and the outline brings out detail especially in the clouds and water.
Gene S Morgan
Filters: 81
I design T-shirts and specialize in music related artwork. I create the artwork lots of different ways. My site is called Captured Image Design because I thought in the begining I would use filtered photos of musicians I had taken over the years. Well, unfortunatly for me they have copyright laws that say you cannot sell images of anyone without their express permission. Like that was gonna happen. So I had to make do with some of the few friends I have and me.
This is a photo of me playing the guitar very badly. I used my Fake Buzz filter with a little Pseudo-HDR Color filtering to improve color. I love making people wonder if it is art or is it a photo. Lots of color flakyness and strong texture and outlines.
My Website ... Captured Image Design
Gene S Morgan
Filters: 81
There are certain things that will help a picture look better when printed. I have found that to lighten up an image a bit and kick up the saturation will make a picture look better when printed on satin or glossy paper. A lot of my music photos have been printed in music organization newsletters. I take photos at roots music festivals whenever I can. I had one newsletter editor who would always come to me at his fest and ask me to make sure I submitted my photos. He always printed whatever I gave him, not because I am any kind of great photographer, but because I always prepared them for print. Increasing contrast and saturation really makes an image jump off the page.
This photo of Larry McCray at the Mississippi Valley Blues Fest was prepared with some color correction and my Fake Buzz filter to add detail with outline.
Gene S Morgan
Filters: 81
Some photos taken on a night stage are hard to get looking good because the background is so dark and the stage light make the musician glow and loose definition. In this photo of Eddie “The Chief” Clearwater I used my Fake Buzz filter again but with some extreme settings to really make it pop. You may notice that when enlarged it looks pretty rough with splotchy colors. The fact is that pictures printed on newsprint stock are usually only a couple of inches in size. When they are that small it is hard to see the roughness and the color intensity really makes the photo look good.
My T-shirt site ... Captured Image Design
Gene S Morgan
Filters: 81
I have been showing ways to improve images for printing. To me the key issues are contrast, detail, and saturation. I have used filter of my own making to illustrate my methods. Folks may say I do this because I believe my filters to be better than others. The truth is that I believe that there are many filters far better than mine. You could get very good or better results from using some of these other filters. I have been a potter in the past, and one of the coolest things in pottery is making your own tools. You carve different shaped tools to use to shape your pots in different ways. I look at FF the same way. I like using tools I have designed for my own special needs. But you don’t need to use my tools to get good results.
I’m going to use a photo of singer songwriter record producer Bo Ramsey taken at the Mississippi Valley Blues Fest as my test image. I have said, taking pictures of musicians is not always easy. There is some blur in the image and because of the stage lighting his face is a bit fuzzy. We will see if we can improve that.
Gene S Morgan
Filters: 81
This is an example of increasing contrast. Way back with the first KPT set of filters there was a filter called Color Contrast. With it you could create contrast that did not effect just light and dark but also the intensity of color. Using a method based on high pass sharpening you can add contrast to and image that affects all the colors. My HDR Color Contrast filter attempts to do this. That is what I used in this example. Notice how the face takes on more definition and sharpness. This image would be best viewed at a smaller size as the full size seems a little overdone.
Gene S Morgan
Filters: 81
This is my favorite style of art design. In truth it makes the photo look pretty unreal or you may think a little too real. Lots of color smoothing and detail added using outlines. In this case I used my Pseudo-HDR Illustrator filter. This style always looks good in print. There are lot of good outline and cartoon filters here in the library. The thing I have never seen mentioned, when using outline methods such as those filters and mine, is that some really exact fine tuning of the results can be made by adjusting the Pixels Size slider. In this image I had that slider to the far left, which made the outline look more like slight grain and detail in the image. That makes it less cartoony and more graphic art like.
Gene S Morgan
Filters: 81
This filtering is similar to the last, but I did more color manipulating. It created a kind of dry brush look to some of the color. I like how this makes the face look. I like the way the grain and detail enhances the shapes on the leather jacket as well. I used my Old Book Illustrator with this image.
Gene S Morgan
Filters: 81
This final image would work well when printed on newspaper stock such as used in most newsletters and newspapers. It has nice strong colors and areas such as the face and guitar look sharper and would look good printed at any size. I used my Fake Buzz filter on this image. This filter was one of the first type of filter I tried to create, but I never got very good results until FF V2 came along and added the medium node so I could get better smoothing. Also you may see why I believe a hue/saturation node should always be near the end of any filter. Having good control over color is important and makes all the difference in the final image.
Gene S Morgan
Filters: 81
You may notice that several of my filters have HDR in their titles. High Dynamic Range effects give the ability to increase the range and brilliance of color and improve detail. The normal way to achieve this is by shooting a number of bracketed images and layer them together, combining them with different modes. Man, that sounds like too much work for me. I try to fake it. There are several commercial filters such as Topaz and some online tutorials and actions that can create Pseudo-HDR images. I used ideas from some of the tutorials to try to come up with my own versions of fake HDR.
This image was taken on a windy rainy day on Oahu’s North Shore. I actually don’t think it needs any improvement. When I see it I am reminded of a specific time and place. This moody image makes me feel the damp breeze on my face and smell the salty ocean mist. Let just say we need a postcard image. We need some HDR magic.
Gene S Morgan
Filters: 81
OK, more detail and sparkling colors is just what we get after running my Pseudo-HDR Color filter on the image. It’s perfect for a postcard to send home to let folks know it’s always sunny and perfect in paradise.
My T-shirt web site .... Captured Image Design
Gene S Morgan
Filters: 81
Another element of HDR photography is the increase of detail. That with the increased color range gives the image a kind of super realism. I started with this pumpkin image.
Gene S Morgan
Filters: 81
There are several HDR software programs that can create effects that imitate the process. Rather than try to create one filter that does it all, I have made filters that try to duplicate different elements of HDR. When I try to make large complex filters they seem to run very slow. Slowness is my enemy. I get bored easily. I have read other folks suggestions and seen the tutorials, and try to follow the suggested practices. I must be missing something. Maybe I’m expecting too much. Guys who do a lot of 3D work are used to long render times but I fall asleep waiting. Maybe I don’t get enough caffeine. I think it has to do with blending. Since I look at Photoshop effects as layer effects, blending is the main means to an end. Every blend seems to add more time to each render. It would be nice if FF had a multilayer blend node with blending modes on each layer. But, anyway that is my excuse for doing filters in pieces rather than make a really useful filter.
The pumpkin image was created with my Pseudo-HDR Illustrator filter. It basically uses an outline method to increase the look of added detail.
Gene S Morgan
Filters: 81
HDR taken to extreme can produce some very nice effects. I like the look of real and unreal together. We will start with this dark cone flower picture …..
Gene S Morgan
Filters: 81
Close-up photos of flowers are always pretty cool. When taking close-ups you often get a depth of field effect that has the flower in focus and the background kinda blurry. With a little extra filter manipulation you can turn the background into a bit of an abstract. Using my Pseudo-HDR Illustrator filter I was able to alter the color and detail and produce an impressionist like computer painting. I like most the way some of the background greens turned a pale blue, making the weeds and grasses look sort of unreal. In Photoshop I gave the image some extra saturation.
My T-shirt Web Site ... Captured Image Design
Gene S Morgan
Filters: 81
This field of clover photo was treated in a different way than previous ones, but the results have a similar look to them. The before image is a bit flat.
Gene S Morgan
Filters: 81
I ran my Smooth Grain Outline filter on this picture. It is not a HDR filter, but it does affect color range. To create a different look to the color and outline I used the median node on the image to make the outline look somewhat different than the usual outline. Instead of ending with a black outline you get some extra color and saturation control in the final image. That is accomplished by allowing the outline to remain in color and using a multiply blend . You get a color and sometime a color grain boost. It is a nice effect with some images.
My t-shirt Web Site ... Captured Image Design
Gene S Morgan
Filters: 81
The example photo I use here is a not very interesting image of a Fort Lauderdale beach. It is too busy with no real center of interest to draw your eye to. A few years ago, not long after I took it, I ran a fake watercolor action on it and sold a couple of framed copies. I was never very happy with it and pulled it back out recently and fooled with in in FF.
Gene S Morgan
Filters: 81
I ran my Color Grain Paint filter on the image. It is similar to some of my HDR filters in that it affects color and detail. But, it also can make the shadow areas more intense and produces a color grain. I like color grain. Back in the old days I used Tri X 35mm film because it had a nice grainy texture. I find color grain to be even more interesting. This is a kind of weird filter. With all kinds of different blending modes I combine 3 different outline effects to create a pretty complex blend. That is how I was able to bring out the grain and produce hard shadows. I like the grainy texture in the sky and sand. The most interesting part is the pattern of shadow of the palm trees that draws your eyes to the lower right corner of the image. That kind of makes this rather dull image more interesting.
Gene S Morgan
Filters: 81
I want to thank all you folks that have checked out my t-shirt site. It has upped my google rating a bit. It was never my intent to get you folks to buy my stuff, but it is really cool to me that some of Y'All took the time to have a look.
My T-shirt site is .... Captured Image Design
