Cool!!! smile8)
nice depth. i think i've only seen that much once in a filter before.
WOW!! This is very good and well done, and as Kraellin have said, it has a good depth feeling, I could never know or discover how to make this with FF, this is only available to expert and masters of FF.
Anyone else than uberzev knows how this could be done?
Here are a couple thoughts: probably created 1 corner and then reflected those on all other corners. My other guess is that it was done in one shot, or the whole grid was generated in 1 go. You can distort images using scale or xy lookup. That's pretty general. Oh well. Not like I know exactly myself.
Sharandra
Filter Forge Addict
What Skybase said.
Do some experiments! smile:D
Sharandra
Filter Forge Addict
Hint, my approach involved polygons and a scale component. It´s very simple.
Now go do your homework and replicate it! smile:D
Cool and well done Sharandra, great example smile:)
Pretty close... although the method is probably very different. Uber's grid is from 2008, rather different a task back then.
Still experimenting in this without knowing how to do it right, will have to keep thinking for a way to do it and replicate what you 2 have already shows here above
Also I wonder if it could be done also the opossite, I mean to have the center go inward, instead of outward and the estés go outward. Instead of inward
